Question about HTC Tilt 8900 Smartphone
Need manual for pt-1700 I erased my HTC Home because it wasn't loading....now what do I do????? Also I'm having problems with the contact points of the USB in the phone. I have to juggle the charger around to make contact.
  • 139 Answers
Hi
Shmuelbuddha you can download the manual from the following link.
http://www.brother.ca/en/customer_care/user_manuals.asp?id=2668513535812699781
http://www.devicemanuals.com/guide/Labeller/Brother/Brother-PT-1700-Office-P-touch-labeller-User-T0RFMk56TT.html
Enjoy this is a free and a confirm download.
Posted on Jan 15, 2009
  • 19,396 Answers
Here is the manual: PT-1700
I need a manual for my daisy powerline model 1700 co2 bb pistol
You can contact daisy and they likely have the manual, you will need the serial number etc.
http://www.daisy.com/customerserviceform
Nov 08, 2013 | Daisy Toys
Avr-1700 airplay
I have the same problem. Please let me know if you were able to find a solution. Carzev@yahoo.com
Dec 21, 2012 | Harmon Kardon Harman Kardon - Avr 1700...
Training manual for maxxus
I have found many manuals just by checking online, i.e. "maxxus trainer manual", and see what pops up. You'd be surprised. If that doesn't work, contact the dealer.
Feb 05, 2012 | Concept Bayou Maxxus 1700 XL Total Body...
Ok so i got a G1, and the problem is it wont turn on. even when i charge it, it wont turn on. The farthest it goes it to opening where it says G1 and then it turns off after that. Whats wrong with it, do i...
Try hard resetting it once. But make sure you have enough charge. But this will erase everything.
To perform a Hard Reset
  1. Turn the phone off. If it is frozen, take the battery out and put it back in.
  2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
  3. Press Alt+L.
  4. Press Alt+W for a factory reset.
  5. Press the Home and Back keys again for about 25 seconds.
http://www.resetcellphone.com/solution/HTC/g1
Jul 27, 2011 | HTC G1
When i exit a app and go to home i get a white screen that says htc and then it starts to reload. how do i fix it?
Try this: From home screen touch menu then go to settings then privacy then factory data reset and finally reset phone. This will reset you phone and prompt you to activate it when it starts up. This will erase all of your apps but not your contacts as they are sync'd with your Google account. This should fix your problem unless it is a hardware issue. If it is indeed a hardware issue take it to Verizon.
Mar 05, 2011 | HTC Droid Incredible Cell Phone
How to open the packet data?
Hi keich...
To open packet data Goto
Menu>Web>Browser or Goto Address
Enter address>ok
If it gives any error
Try the following
*First contact your network operators customer care check whether internet service of your number active or not If it's already active request them to send internet settings save and activate these settings
if problem persists Restore factory settings by Menu>Settings>Restore Factory Settings>(Default Security Cide will be 12345)
Then also problem persists contact your network operators customer care ask the accesses point name(you can create a internet setting manually by Menu>Settings> Configuration Settings>Personal Con Settings>Web>you can enter home page as you wish(ie:any website id) select "use pref access pt"to no>Access pt settings>Proxy to "Disable">Bearer settings>Packet data acc pt>enter the access point what they provided
I hope this helps.....
Than you
Feb 16, 2011 | Nokia X3 Cell Phone
Keep getting com.HTC.launcher has quit working. Will not load home page.
hi grfdadam . First take your battery oput of the phone let do a soft reset on the phone. Next you have to make sure you have all the information when you first activate te phone. If you see that your phone is still not working . Their is a reset button on all htc phones. Now yuid will erase ll your information on the phone. You will have to reactive and reset up evertyhing on the phone. Now you could go to htc's site and check to see if they havea soultion for this problem. I can only tell you what to do but htc knows their phones and if they are see a problem on a regular bases and what fix they have. I hope this little bit of information helps
Dec 06, 2010 | HTC Hero Smartphone
Error 99
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Mar 16, 2009 | Canon EOS 40D Digital Camera with 17-85mm...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
HTC Tilt 8900 Smartphone Logo
268 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
