Question about Uniden DCT6485-2 Cordless Phone
The none base phone wont work
When I first got the phones (they are used), I plugged them in and they worked fine after they were charged. Now, one of them doesnt work. The one that isnt the base phone. When I pick it up and press talk, it beeps three times and wont let me use it. The screens are broken, so i cant see whats on them, but the problem isnt the battery, I tried it in the other phone and it worked fine. I tried to switch the outlets, but its not that either. I put it on the base charger and tried that, that didnt work. I unplugged the base phone and that didnt work. It worked when i first got it, but now it doesnt. I want to either know how to reset it, if there is a way, or just know how to fix it.
SOURCE:
  • 281 Answers
SOURCE: Main base not charging
no you need a new battery. Hope this helped you
Posted on Feb 25, 2008
  • 3 Answers
SOURCE: Out of range
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Posted on Mar 23, 2008
SOURCE: 2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Posted on Dec 08, 2008
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
SOURCE: Base handset out of range
Try opening the phone battery compartment on the back of the phone, disconnecting the battery wire, then reconnecting the battery wire. Solved my "Out of Range" problem - phone came back on and worked properly.
Posted on Nov 16, 2009
How do I link handset to base after power outage CS6529-3
You set the cordless phone back into the charging base. After a few seconds (longer if in need of a charge), the cordless will register with the base establishing the connection required to place and receive calls.
Feb 19, 2015 | Lands Phones
On the main base no charge light, none of the phone works
Hi,if no power on the base it is normal that none is functional...make sure you have a power adapter is connected to Base...if no light it means either your adapter is malfunctioned or just it's cable is broken from the base side nearby plug..to testing purposes you can use other power adapters on the base...just to aee light is on..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me
to continue f
or Helping out the Community :)
Thanks
Aug 16, 2011 | Uniden Cordless Phone
Hi, I have a vtech phone model ia5823 which works fine. I have been given another phone and base to use as a 2nd phone exactly the same model. I have charged the 2nd phone but it cannont connect to the...
Take the first phone off from the base and turned of.Unplug the power from the base. Put the second phone in the base. Plug in power in the base. The base must search the new " IP or code "of the second phone. Turn on now the first phone , you should hire a small beep on the base or the unit and should be OK. Both must working now. I wait for an answer.
May 08, 2011 | Cell Phones
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
My sony xperia wont charge I connected it with the std supplied cable and it wont charge ?
Standard charger only charge Li-Ion. X10 is using Li-Po. So, make sure it is compatible.
May 02, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Cordless phone wont work properly
Unplug The Base than take batteries from the phone after 15 seconds power it back on, viola you should have it working
Apr 02, 2009 | AT&T 2.4 GHz 2255 Cordless Phone
Panasonic handset, KX-TG5632 buttons won't work
After trying all possible solutions (unplugging, replugging unit; switching batteries and, my idea of smacking the handset with my hand), I bought a new phone. :-)
Feb 07, 2009 | Panasonic KX-TG5632 Phone
Base unit line 1 is flashing no dial tone
We followed your instructions and are not sure what worked, however, this AM phone line is working.
Sep 30, 2008 | Uniden Cordless phone EXS9950
Nokia 3250 charging problem
it sounds like a problem with the charging port (where you actually plug the charger into your phone). unfortunately, you may have to replace the phone, as switching batteries or chargers wont solve the problem.
Sep 24, 2007 | Nokia 1100
Open Questions:
See all Uniden DCT6485-2 Cordless Phone Questions
Uniden DCT6485-2 Cordless Phone Logo
50 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
