Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
I hav a Panasonic KX-FM131BX fax machine and the problem is when calling or sending a fax you're unable to hear the other fax or telephone ring.
    Genius:
  • 2,120 Answers
Check the phone line with a regular phone
Posted on Jan 18, 2009
I have Panasonic kx-Fl 402 FAX machine. The port of fax and telephone line is OK. But there is NO ringing tone in the FAX. Please give me solution.
Dear
Pl.sett the ring pattern and ring volume for the fax machine. Pl. follow the link for the setting detail..
ftp://ftp.panasonic.com/faxmachine/kxfl421/kx-fl421_om.pdf
Thanks.
Mar 06, 2015 | Panasonic Office Equipment & Supplies
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
Want to connect fax machine to pc
The KX-FM131BX, KX-FM131CX and KX-FM131AL do not connect directly to a computer. They only have RJ-11 connections (to the phone line (line in) for all models and to another phone or answering machine (in some cases).
To send and receive faxes with a computer, you need some sort of USB or network port on the machine. Brother has some that may fit your needs: http://www.brother-usa.com/Fax/ModelDetail/2/FAX2840/Overview is one of their lower end models.
I hope this helps.
Dec 06, 2017 | Panasonic KX-FM131 Fax
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Apr 05, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
# of rings before answering
Check to make sure you do not have distinctive ring option turned on.
Feb 05, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Faxing problems
if you put the document in right direction(face up or face down)-your scanner unit may be out of order or unpluged firmly into the main board socket check it and reinsert scanner unit plug again.
Jan 10, 2008 | Panasonic KX-FB421 Plain Paper Film Fax
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
85 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
