Question about Hampton Bay AC438-VPW 52'' Vintage Pewter Fan
Remote calibration I just installed 5 of the same fans in one large room. They are working fine except the remote control is not calibrated to all the fans resulting in uneven lighting levels I tried pointing at each separate fan but they cannot be isolated. Any ideas?
I installed three fans in the same room and one remote ran all three. In order to get the dimmers all to bring the lights up and down together, I changed the dip-switches in the fan housing so that the remote would only work one fan at a time. I then brought the dimmer lights all the way to bright. After all the lights were equally bright, I again altered the dip-switches so that all three and the remote were identical. The remote then dimmed all three lights equally.
Posted on Aug 25, 2007
SOURCE:
Calibration of t701 thermostat
Page 8 tells you how to calibrate
Room Temperature Calibration
This feature allows the installer to change
the calibration of the room temperature
display. For example: If the thermostat
reads 70° and you would like it to read
72° then select +2. You can adjust the
room temperature display to ready -4°F
to +4°F above or below the factory cali-
brated reading. Follow the steps below
to adjust the temperature reading:
Select
OFF
with the
system switch.
Hold down the + and - keys together for 3 seconds.
Use the + or - key to adjust the room temperature
display
http://www.toptechparts.com/resources/tt-n-701_in_man.pdf
Sep 02, 2018 | Dryers
My 2007 checy impala read "calibration complete" what does that mean ????
CALIBRATION COMPLETE
Refer to Electronic Compass Calibration do you have an owners manual ?
Compass Calibration
The compass direction will show CAL if it needs to be calibrated. Before calibrating the compass, drive the vehicle to an area that is magnetically clean (free of large metallic objects).
  1. Turn ON the ignition.
  2. Before calibrating the compass, make sure the compass is set to the variance zone in which the vehicle is travelling. See Compass Magnetic Variation Adjustment below.
  3. Press the vehicle information button until the PRESS TO CALIBRATE COMPASS screen is displayed.
  4. Press the set/reset button to start the compass calibration.
  5. The DIC will display CALIBRATING: DRIVE IN CIRCLES. Drive the vehicle in circles at less than 8 km/h (5 mph) to complete the calibration. The DIC will display CALIBRATION COMPLETE when the calibration is complete.
Oct 02, 2016 | 2007 Chevrolet Impala
2nd remote paired to two fans.
close the door and turn off power to that room and then try again
May 24, 2015 | Televison & Video
Can't turn off fan when light is on
Not sure, but if its a new installation, I would say that the wiring has been done incorrectly. Ceiling fans with lights should be able to work independently. both on / off or 1 on, the other off.
Feb 22, 2014 | Televison & Video
Remote is inaccurate
did you change the batteries ?
Dec 07, 2013 | Mitsubishi Heating & Cooling
2006 Expedition overhead compass reads "N" when heading "E". Wonder how to reset it so it indicates the direction accurately.
Yes. Wish I could tell you which button for sure, but to reprogram the Compass you hold one of the buttons and drive in a circle one or two times to reacquire your position.
Apr 08, 2013 | 2006 Ford Expedition XLT
My trailer furnace is a coleman DGAA. everything seems to be running good except cool air is cming through vents. takes a long time to get my olace warm.
1 of 2 things, 1, check calibration to match control amperage, 2, check fan switch, but if you have ever changed the thermostat it more then likely your calibration. GARRANTEED
Dec 30, 2010 | Coleman Heating & Cooling
Tony hawk shred board will not calibrate on my xbox s console. tried it for hours everyway I can think, any suggestions?
My husband was ready to throw this game out the window instead of returning it because he was so upset...so nice for our 10 year-old on Christmas morning. Researched online and lots of people said putting two older batteries into the board with two of the new ones. We did that and also had to move the couch into the hall and then it finally calibrated!! Don't give up keep trying everything but the two older batteries helped. Once it was calibrated we moved the couch back and it seems to work fine. So far it seems like a cool game!
Nov 25, 2010 | Activision Tony Hawk: Shred
Hampton Bay AC438-VPW 52'' Vintage Pewter Fan Logo
177 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
