Question about Mitsubishi WS-55411 55" Rear Projection Television
Do have power and sound, do not have picture
My mitsubishi ws-55411 55 in rr project. tv lost its picture. everything else seems to be working properly. How can i check out this problem?
  • m_hutchins Jan 16, 2009
    There is no picture at all. The screen is black, no light.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Do you see any display on screen? Does TV show picture on any input or it just went down?
    Champion:
  • 240 Answers
This unit has a self test check you can do
when the set shuts down or when the set is turend off.
press and hold , onthe front of the set the input or device button, and hold the menue button for bbout 5 seconds.
the set will flash a 2 digit blink code at you.
12 blik = no problem
21 blink = xray protect
22 blink = short protect
23 blink = loss of deflection.
regards,
daniel.
Posted on Jan 15, 2009
No picture on tv just blank screen
Sounds like you lost your High Voltage Power source which lights up your screen. If you don't know anything about TV's do not attempt to fix this problem. The High Voltage Power Supply is around 40,000 Volts!
Mar 26, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Mitsu model #ws-55905 Started losing picture while watching a DVD. The next day it worked fine. Now it lost the picture and sound completly. I have no response at power on, only the green power indicator....
actually something on the main board was getting overheated before due to that it was loosing the picture.and now that component is got totally overheated and blowned/burned out.so its quite necessary to replace that faulty component from the board by checking it with a meter.so its advisable that you do not turn on your tv to avoid further damages till it gets repaired.
Feb 20, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
TV needs to warm-up
Check the power setting in the menu. If it's set to low power, switch to standard.
Nov 11, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55411 55" Rear Projection Television Logo
145 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
