Question about Acer (4432A-002) CD-RW Burner
My computer working slowley - Acer (4432A-002) CD-RW Burner
  • Acer Master
  • 19,396 Answers
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Posted on Apr 28, 2009
Fix backlihght
you need to take all the small screws from around the edge of the screen then very slowley pull it away.then pull the screen very slowley away from its case and behind the screen you will have ribbins on the back of the screen pull them of, then you take of the converter thats at the bottom the screen,and to put it back just do it the same way you took it off.
Jun 22, 2014 | Acer Aspire 4520-5582 Notebook
Youtube videos load very slowley. face book videos load slowley
are you getting any error message may be due to slow internet page.
Jan 18, 2014 | Computers & Internet
Brake pedal works at ferst then travels to the floor
Usually a sign of a failing master cylinder. One of the seals inside is allowing the fluid to bypass the piston.
Aug 27, 2012 | Ford F-150 Cars & Trucks
When driving or gust cruising, when i step on the gas peddal to slowley start to excelerate the engine bogs down ansd acualy decelerates. if you push down a little harder on the peddal it slowley drops...
Have you checked out your air filter? Has your 02 GMC Envoy had a tuneup? Also you may need to replace your fuel filter as well. (especially if you drive in a dusty area) A vehicle as new as yours still needs preventive maintainence to keep the "new" parts working properly. While this won't stop the components from eventually breaking down and causing you headaches, its still a good idea to check these things.
Jul 11, 2011 | 2002 GMC Envoy
What side of the skimmer does Filter Media get placed? We placed in on the side with the pump and it is getting caught in the pump causing it not to run.
You can clear this by opening the pump and running a high presure hose it to center of impeller and let it run out the lid hole, or take pump apart and rinse it out that way. once you have the pump running again mix your filter media in a bucket of water and pour it slowley into the top of your skimmer while your pump is running. slowley being the key word here.
Aug 16, 2009 | Savio Skimmerfilter Base Unit, Black Lid
Very slowley
Your bios is not set correctly, or your motherboard is not capable of supporting the processor.
Jan 24, 2009 | AMD Sempron 3100+ 1.8GHz 256k Socket 754...
Any advice my dryer is not working anymore it will not dry the clothes
The most common problem would be a restricted vent. Turn the dryer on and go outside to the vent outlet. Air flow must be fairly strong. If not, clean vent piping and eliminate as much flex ducting as possible. You want the shortest, straightest, smoothest (inside) vent possible. If air flow is strong, clean the two silver bars inside the dryer drum near the lint filter with some rubbing alcohol. If you still have problems, send an "ask me" note with as much info about your symtoms and what you have tried so far. ie: is there any heating? are the clothes unusually wet before going into dryer? has this situation come on slowley or suddenly? are your clothes drying very slowley, or not at all? does the dryer run for hours, or does it stop?
Aug 28, 2008 | LG Dryers
Open Questions:
Přeji hezký den. Mám velký Přeji hezký den. Mám velký problém s dvd mechanikou ve svém PC. Pc mám cca dva roky a dvd mechaniku jsem sotva využila 5x. Před nedávnem jsem pro svůj pc využila doporučovaný program na vyčištění Cleanr a nechala ho dělat svou práci bez mého zásahu a po té, když jsem chtěla spustit dvd, tak dvd mechanika se mi otevře, vložím dvd a zavřu, chvilku světýlko bliká a nemá to snahu ani začít načítat a tím se tedy ani nespustí. Prostě vůbec nereaguje. Zkusila jsem aktualizovat ovladač (mám u něj vykřičník) a to mi vykázalo, že ovladač je správně nainstalovaný a funkční. Tak co mám ještě udělat, abych vlastně skoro nevyužitou dvd mechaniku ve svém pc mohla používat? Omlouvám se, že se tak rozepisuji, ale bohužel moc nerozumím technickým záležitostem v pc. Softwer ovladače je : HL-DT-ST DVDRAM_GSA-H40N ATA Device model pc: ASPIRE M1100 ( ACER ) rating : 220-240Vac,3.15A,50Hz Opsala jsem co se dalo, pak je tam jen S/N + číslo a SNID + číslo. Budu moc ráda, když mi pomůžete. Dopředu děkuji a přejei krásný den. S pozdravem Bundzíková Světlana
Feb 28, 2017 | Acer (4432A-002) CD-RW Burner
See all Acer (4432A-002) CD-RW Burner Questions
Acer (4432A-002) CD-RW Burner Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
