Question about Sony Handycam DCR-VX1000 Mini DV Digital Camcorder
I need help fast please!!!!! vx1000 is making a beeping noise when then ejects the tape
The tape mechanism is acting up. It allows you to load a tape but then it just ejects it and the camera beeps. This is not the typical "jammed" tape deck issue that these cameras have. I only used this camera 3 times before it went down, and all functions were working for me prior to the failure. Please i need help fast!!!!!!! Thanks for your time
  • 2 more comments
  • Andy Parauka Jun 16, 2007
    how much does that part cost?
  • Anonymous Dec 04, 2007
    I have the same problem does anyone know of a link or something i could use that would show me how to replace it?
  • mcrickyd Feb 26, 2008
    Same problem, no idea what a chassis sub block assy is, or where to put it.
  • rockstarwsty Jul 12, 2008
    My vx1000 will allow me to insert a tape and play it, but as soon as I try to record, it beeps and starts flashing a eject icon.
    Sergeant:
    Champion:
  • 326 Answers
Hi there, in order to solve this problem best solution is to change the CHASSIS SUB BLOCK ASSY part number: A7026023R If you need more info please contact me at LIVE session. Best regards, Arpi
Posted on Jun 16, 2007
  • Arpad Kothai
    Arpad Kothai Jun 17, 2007
    the price is about 50 US$, please check these links: http://sony.nexttronicsparts.com/comersu... http://www.partstore.com/sl/2/indexd1819...
    If you need more info please advice.
    Arpi
  • j58sd Nov 10, 2010
    hey thanks for posting this but the links dont work and im having trouble understanding what this part is and where it goes
  • 298 Answers
6ya staff
SOURCE:
Sony handycam ccd-trv59e C32 10
The camera's firmware has sensed a jam or too slow rotation in the cassette's take-up roller. Really difficult to overcome. The tape may already be snarled round a roller, but is certainly in the "loaded" tape path. I've had this and had to disassemble the whole tape transport mechanism - which is really difficult - after trying unsuccessfully to drive the unload motor from an external 6v power supply. Sometimes a really hard sideways bang on the camera can free up the roller enough to let it rotate a bit, satisfy the motion sensor and allow an eject.
Jul 07, 2014 | Sony Handycam DCR-TRV520 Digital Camcorder
VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Jan 28, 2008 | Goldstar GBV241 DVD Player/VCR
I am a electronic tech and I had a DRCTRV950 come into my shop and I am trying to help a friend out getting this camcorder running. The problem I am having is everything seems to work right except when you...
This can occur when the heads do not spin up fast enough or the loading does not complete. Check for slipping of the loading belt. There is more load placed on the loading motor and mechanism in total when the tape is actually there. The flashing Eject indicates that the load did not complete.
Hope this helps a bit.
Dan
Oct 15, 2009 | Sony Handycam DCR-TRV950 Mini DV Digital...
Canon elura 90: won't load tapes
Make sure the power is on this unit and you are pluged into a good source of power. The disk tray needs power to lower. A lot of tapes get loose in there case and need to be fast forwarded and then rewound completely in order to help spool them properly in their case. And what you are experiencing sounds a lot like this. It is also possible that you need to buy a head cleaning unit for your elura and run it in the camera for 10 secs and then try again. (Did you try this with a New tape? or just used ones?) We bought a small tape rewinding unit for around 39 dollars that helps us to rewind the mini DV tapes without adding wear and tear on our camera and it seems to help with the issue of loose tapes in the camera getting rejected as they won't wrap around the tape head as nice.
Dec 14, 2008 | Canon Elura 90 Mini DV Digital Camcorder
MINI DV TAPE WON'T LOAD
First power off the unit, then remove the DV's tape housing , power up the unit, and allowed the mechanism to go back to the unload mode, make sure that the tape posts are at unload mode. then unplug the vcr back again, put back the tape's housing in the load position (tape in) power the vcr back on and push eject button to reset tape mechanism.
Jan 16, 2008 | JVC HR-DVS3 Mini DV/S-VHS VCR
Canon zr300 ejects tapes
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Dec 04, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
High pitched noise, then ejects tape
Hi friends. (Excuse my poor English). Well, i bought a SCD364 Samsung CamCoder that is physically and mechanically exactly as scd363. My scd364 also have the same problem. Because the warranty has expired, i discovered a solution. The problem ocurs due to a missing calibrati?n at tape motion mechanism then when the cam goes heat, the motor grazes with another part of the mechanism that this located very near (wax)causing a metallic noise, eating the battery and, finally the blinking "D" eject signal. I amazing when discovered that the solution is to open the tape compartment and place the opened camera infront of the air conditioning machine by 2 minutes in order to cool it. Once cold, the camera is ready to play or record again without noise and blinking "D".
Jun 04, 2007 | Samsung SC-D365 Mini DV Digital Camcorder
Ejects Tape after high pitched noise
Sony Handycam DCR-VX1000 Mini DV Digital Camcorder Logo
764 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
