Question about Sharp AR-5316 Advanced Digital Imager Copier
Code H and sometimes 4 appears in my photo copy Machine.
Please help
  • 145 Answers
Enter the folowning
program, interupt , clear, iterupt to access the service mode
and than enter # 14 and press start botton
good luck
Posted on Jan 19, 2009
Ricoh MPC4500 sc290 error code
Hello, here is the error code manual for your copy machine. Error code 290 is on page 4.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC4500&page=4
Good luck
Feb 02, 2014 | Ricoh 400879 Color Photo Conductor Unit...
My copier machine Toshiba 7230 have error code CD10 when I'm copying. Sometimes The message "reboot machine" appear. How to solve the problem?
try pulling out the plug if that doesnt work try pulling the battery I believe by shutting it down you can reboot it. GoodLLuck to ya.
Dec 19, 2012 | Office Equipment & Supplies
The printer turns on but afterwards it displays 1, P, 0, 7. then it repeat displaying P07. What does it mean? Please help me. Thank you. God bless.
If my answer helps you, please give me a 4-thumbs up rating.
This error indicates a service problem with the printer. Sometimes recycling will fix, or the paper path may be jammed.
Here is an excerpt from the manual for this error code:
Turn off the machine, and unplug the power cord of the machine from the power supply.Plug the machine back in and turn the machine back on.If the problem is not resolved, contact the service center. Print this out and you can have a list of the error codes for reference. http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#ServiceAndSupport
Aug 04, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
One number of photo copy machine drum cartridge wasinstalled. It worked once. Now machine is showing letter H and 4 flickering alternatively on the screen. Because of this none of the function of machine...
This code is almost always a false code. I would try clearing it by entering the following key sequence:
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" (Note that the exposure mode key is the far left key and that these 4 keys must be pressed within 4 seconds)
The display should have gone blank if these 4 keys were pressed properly.
Now enter 14 as if you were making 14 copies then press the Print Button.
This should clear the H4 code and the machine should operate normally.
If not and the H4 comes back then you have either a thermal fuse or heater lamp failure.
Good Luck
Nov 10, 2009 | Sharp AL 1631 Copier
What does ap mean
"AP" stands for Agitation in Process", it appears in the copy quantity display when toner is being replenished inside of the copier. Wait a few minutes..this happens after continuously copying for long periods, or copying dense things like photos. Sometimes it will occur after running the machine when it is out of toner. replace toner and turn on/off a few times to "agitate toner. Don't worry about the scan lamp being lit while this is happening, it will go out.
Hope this helps
Sep 08, 2009 | Copystar CS-1810 Copier
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
Change Language on Brother MFC-215C
So here you go:
1# Call brother hotline for info what is the 4 Digit eeprom code for England.
2# If you have the info (e.g. 0004 -> Check by help of brother hotline because I am not sure what code you need for GB!!!)
press menu then start bk copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press 7 then 4. You will see the dutch eeprom language code. Press the 4 numbers given to you by brother hotline. You should see the 4 digits. Press start bk copy to confirm. machine will return to maintenance.
press 9 then 9 to leave the mode. machine will come up again with english language ;-)
BEWARE: IF YOU PRESS A WRONG DIGIT CODE THE MACHINE WILL BE MALFUNCTION AND CANT BE FIXED ANYMORE!
Dec 30, 2007 | Brother Multi-Function Center® MFC-215C...
Not printing
hi i have similar problem .error code 5a .can you help ?
Oct 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
