Question about Toshiba 50A61 50" Rear Projection Television
Toshiba 50A61..power comes on but no picture or sound
We had a Thunder storm in the area. I unplugged the power cord and cable connection. The TV was working fine when I did this. Later when we turned it back on the power light comes on and you can here it click on, but there is no picture or sound...I am having a difficult time finding someone to look at it so just wondering if it might could be an easy fix or I should just buy another set. I have had it since 2002. Thanks
  • Anonymous Nov 06, 2008
    same storm power comes on but no picture
La televicion toshiba mod 50a61 se quema el str aun cuando es nuevo y oiginal que esta causando esto alguien me puede ayudar
Posted on Jan 27, 2010
If you are going to get rid of the TV, I would love to buy your remote. I have the TV but no remote. please contact me via email escamillama@hotmail.com
Posted on Dec 14, 2009
Hello my toshiba model 50A61 was working fine too but the image does not show any more. Technicians say is the pc board that has to be fixed and it cost around $450-500 us.......
Posted on Nov 16, 2009
    Genius:
  • 1,074 Answers
My friend your tv got hit before you did the disconnections storm hit sets are a piece of work to fix, it is left with the circuit board burned.my advise is to buy a new tv.good luck
Posted on Jun 23, 2007
  • 81 Answers
There are fuses in this unit, one could be blown there are also capacitors and a regulator that could be at fault I would suggest U find a repair man in your area if possible to go thru this unit find the fault and repair. It would cost less than to repair than buying a new one.
Posted on Jun 22, 2007
I have a toshiba 50a61 projection tv, it shows the menu and comes on but does not show a picture or sound.
I highly recommend you call a technician before you hurt yourself or cause more damage to the TV
Dec 08, 2014 | Toshiba 50A61 50" Rear Projection...
My Emerson lf46iem4 46 inch tv stopped working after a storm... What part would I replace to fix it?
IT COULD BE THE POWER SUPPLY GOT SHOT OR THE TUNER DEPENDING ON THE CONNECTION WHEN IT WAS IN USE .SOME TIMES THE TUNER GOT SHOT WHEN THE SET IS CONNECT WITH THE COAX CABLE LIGHTNING WILL SURGE THROUGH THE CABLE IF IT IS NOT GROUNDED PROPERLY ...GOOD LUCK
Oct 12, 2014 | Emerson Televison & Video
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
HELP! I think my TV got zapped and is ruined from storm!
Check whether the power outlet has power. If it has, I suggest please do not attempt to switch on the TV, unless checked by a qualified service technician.
Aug 16, 2012 | Toshib 46L5200U 46" 1080p LED-LCD TV -...
I have a toshiba 50a61 tv sound no picture
Hi ogmrwizzard,
This is an indication of faulty lamp.
First check the lamp connectors, pull-out, inspect the connectors and then re-insert and ensure its connection from the ballast board. If the symptoms still persist, you must replaced the lamp to back the picture again.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 04, 2011 | Toshiba 50A61 50" Rear Projection...
My JVC AV-48WP55 only blinks the green led when plugged in. This happened after a power surge, during a thunder storm.
Have you tried unplugging the tv and letting it sit for a while then plugging it back in?
also.. sometimes i have seen appliances that will flash the power light if an internal fuse has blown to indicate a problem. open it up if you feel you want to and check for a fuse around where the power cord comes in teh tv.
Nov 18, 2009 | JVC Televison & Video
No sound from tv
Try a "hard restart", which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics to a certain extent.
You can also visit the manufacturer's website or call their tollfree number for problem solving info.
Hope these suggestions help you out.
Jun 29, 2008 | Televison & Video
JVC 48" HDTV Ready Widescreen Projection TV
Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Toshiba 50A61 50" Rear Projection Television Logo
413 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
