Question about Datamax M-4206 Thermal Printer
Datamax dmx-m-4206 printing half of the label
  • 54 Answers
Check for the flatness of the printhead across the platen.
also check to see if the head is not worn(will be white colored at the head heat elements.
also check to see if the platen is severly worn.
Posted on Feb 25, 2009
What is the backing?
The Backing is the see through paper on which the labels are stuck to. It can have a light yellow or white color. While the printer prints, the labels move through the label sensor, usually green in color. The gaps between the labels triggers the sensor to indicate where the printer should start to print.
Hope this Helps. (",)
Aug 05, 2014 | Datamax DMX-M-4206 Thermal Barcode Label...
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
We have several Datamax I-4208 printers and a few of the older I-4206 models. It would appear the replacement printheads are one in the same for both models be we cannot get either of our spares to work in...
Some changes were made on the I Class units and the new printheads do not work correctly in the discontinued 4206 models. You need part number DPO20-2262-01 for your I-4206.
Jan 18, 2010 | Datamax DMX I-4206 Printer
Computer and printer dont communicate we have it on a usb cable dirctly connected from computer to printer we connected our old datamax e-class printer and that one seems to work although the quality is...
its probably a issue of usb 1.0 and 2.0 ..change the usb port and see if the pc its making a sound when you plug it in ..ifthe computer makes a sound like a bel or a ping all you need its a driver for the printer to comunicate with the pc ..and this can be found on the net ..if the printer is Datamax dmx I-4206 this is the driver needed
http://www.mediafire.com/file/mhyjme2ymmz/Datamax.rar
Aug 04, 2009 | Datamax DMX I-4206 Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Aug 25, 2008 | Datamax M-Class Thermal Printer
Printer does not print after change of Printerhead
Put the original printhead back in and test. If the original printhead prints even with missing elements then the new printhead may be bad.
Apr 24, 2007 | Datamax DMX I-4206 Printer
Datamax M-4206 Thermal Printer Logo
920 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
