Question about Nokia 6263 Cellular Phone
Unlock Nokia 6263
I cant get NSS to recognize my phone, even when the usb setting is in "nokia mode"... I want to change the firmware code, but cant get NSS to work.
    Problem Solver:
  • 17 Answers
First off, open Nokia PC Suite. Then click connect a phone. then plug in your phone and put it on nokia mode it might work. And then hit the button in the top right corner on NSS. I have tried to change my firmware code so i can upgrade it but it didnt work for me good luck.
Posted on May 14, 2009
Hi my nokia 2700c imei no. is 353417044680063 i forgot the security code kindly tell me its master code to unlock it
  1. Install Nokia PC Suite
  2. Install Nemesis Service Suite (NSS)
  3. Connect your phone to your PC with data cable. If the phone ask for connection mode, choose default mode or PC Suite mode (But don't open Nokia PC Suite)
  4. Open Nemesis Service suite (NSS)
  5. Click scan for new devices button (on top right corner of NSS)
  6. Click Phone Info button.
  7. Click Scan button.
  8. Under Power Mode, click Local and then click Change button. At this part, your phone should restart, and you should see the text Local mode across your phone screen.
  9. Under Production Data Edit, click Read button. The textboxes should now contain values.
  10. Check the Enable check box beside Product Code.
  11. Click Write button.
  12. Select Tools button on top
  13. Click Factory Settings tab
  14. Tick Full Factory button and click Reset button.
  15. Final step, go back to Phone Info and click Normal then Change. Now your security code is 12345.
Apr 21, 2012 | Nokia Classic 2700 Cell Phone
Hey can i please get an unlock for my nokia 6263 ntm
Several methods are there to unlock mobile phones among that codes are the best way ...........
Get the unlock code for your Nokia 6263 model mobile from this site Superunlockcodes.com , here get the unlock code along with easy instructions for your mobile.........
Nov 26, 2011 | Nokia 6263 Cellular Phone
Hi im having some trouble unlocking my nokie E63.
You can get the Unlock code here
http://www.prounlocking.com/nokia-e63/rs8wp9/ and Unlock the Mobile from Country network lock
OR:
if you haven't upgraded to the latest firmware , you can use NSS to change the product code
to use NSS go to
http://senseapplied.com/index.php/how-to-use-nss/
for product code you can use
0576447: E63-1 RM-437 Country Variant United Kingdom GB CU Blue
0576446: E63-1 RM-437 Country Variant United Kingdom GB v1 Red
0586830: E63-1 RM-437 O2 Ireland IE Black O2_COLOR
after changing the product code , reinstall the firmware via Nokia Software updater and you will be all set
Jun 07, 2011 | Nokia E63 Cell Phone
Hey can i please get an unlock for my nokia 6263 IMEI# 356958010742361 - it will be highly appreciated if u can do so.
To Unlock the Nokia 6263 model Phone use the Unlock code,get the Unlock code
at
Mobileunlocksolutions specify the Network it locked ,country...
Jun 02, 2011 | Nokia 6263 Cellular Phone
Need nokia restriction code 6263 to block incoming calls
you can unlock restriction in nokia 6263 mobile in simple way using this site www.superunlockcodes.com/nokia-6263.
Nov 02, 2010 | Nokia 6263 Cellular Phone
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
Mar 17, 2010 | Nokia 6300 Cellular Phone
I usung nokia 6300 and iam dowloding opera .opera not work my nokia 6300 and how to up grade my nokia 6300
hi may be the opera you are downloading is not suitable for your handset its better for you to not download opera
I bought Nokia 6300b RM-222 with firmware version 4.71, but now the latest firmware is 7.30 (or any latter build). But Nokia Software Updater (link) told me that I already had latest firmware and refused to update my phone. Below I described the steps to upgrade Nokia 6300b RM-222 from version 4.71 (or any other version) to version 7.21/7.30 (or any latter build).
13. Close NSS
Mar 15, 2010 | Nokia 6300 Cell Phone
I need to unlock my Nokia E63 mobile phone, supplied by 3. Can anyone help please?
to use NSS go to
Sep 09, 2009 | Nokia Cell Phones
I need Unlock codes for Nokia 6263 IMEI: 356985013139268
Phone: Nokia
Model: 6263
IMEI: 356985010258046
Please provide the unlock code to anand_k@rediffmail.com
Jul 09, 2009 | Nokia Cell Phones
Unlock e71 to any network
Change the product Code via NSS and then run software updater , you'll be all set . On how to use NSS refer to
Apr 12, 2009 | Nokia E71 Smartphone
Nokia 6263 Cellular Phone Logo
206 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
