Cell Phones Logo
Anonymous Posted on Dec 19, 2012
Factory reset sony experia acro (so 02c) from power off?
Need to factory reset the phone as phone passed on from a friend who can't remember security pattern.
Computer Repairing
Level 3:
  • Cell Phones Master 14,641 Answers
  • Posted on Dec 19, 2012
Computer Repairing
Cell Phones Master
Level 3:
Answers
14641
Questions
0
Helped
718719
Points
53082
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
  • Anonymous Dec 19, 2012
    There is no option to enter a user or security code. I can access the dial pad through the emergency calls option, or choose to answer secret question or put gmail id and password in, neither of which i have the info for. IMEI is 357985040211964
2 Related Answers
Anonymous
  • 19 Answers
  • Posted on Mar 09, 2010
SOURCE: My friend used my phone and put in a security code
you have to go to the store and they will physically put a new lock code in there to make it work yeah its a pain the the **** but they have a special code to re-set the phone.
Anonymous
  • 410 Answers
  • Posted on Sep 02, 2011
SOURCE: i have the LG Vu
Try following this step :
remove sim card and tap emergency or From the standby screen
- Select Dialing Button
- Dial "3845#*500#" (you will then be in the engineering menu)
then reset phone
voila password gone
If that way not worked you need to asking LG Vu CU920 unlock code from your network provider, They will give you the code within 2 week maybe more and takes some charge or you can buy LG unlock code from third party sites complete with details instruction how to unlock your phones. Thank you i hope my solution can help you.
I need to reset a sony experia pm 0090bv st27i
see if this helps you out.
Hard Reset SONY Xperia Go ST27i
  1. Switch off your phone.
  2. Then hold and press together Power button + Volume Up for about few seconds, or until you see menu of your screen.
  3. Follow the instructions on your screen, and confirm operations.
How to Hard Reset my phone - SONY Xperia Go ST27i - HardReset.info
or this link.
https://www.google.com/search?q=how+to+reset+a+sony+experia+pm+0090bv+st27i&rlz=1C1AVFC_enGB797GB798&oq=how+to+reset+a+sony+experia+pm+0090bv+st27i&aqs=chrome..69i57.9658j0j8&sourceid=chrome&ie=UTF-8
tip
Sony Ericsson Experia X1: How to Reset
We can't deny the fact that our cellphones mess up sometimes. That's the truth about the machines, we cannot let them take any medicine so that they'll be fine. However, there some ways on how to make them work again. One of these ways is what we call as reset.
Your phone will come back to its factory settings once you reset it. This is the last thing that you want to do anyway with your phone because this tweak will erase all the files and software that you added in your phone. In other words, it will clean up the whole phone. It is really advisable that you back up your important files like pictures, videos, messages, etc that you have saved in your phone. You can back up your files by using a memory card or any other external devices.
There are two ways on how you can reset your Sony Ericsson Experia X1 phone to its factory settings.
1. Soft Reset
Start>Settings>System>Clear Storage then enter the number 1234 and press Yes.
2. Hard Reset
While the phone is off -hold down the front left and right buttons on the X1 and insert your stylus into the soft reset hole all at the same time.
(Back of the phone)
(Stylus pen on the soft hole)
(Location of the Hole)
After following the procedure, a blue screen will appear which will ask you to press R to reset and delete all your existing files. Just press R. Then, you will then follow the on screen instructions like stylus calibrating. It's like having your Sony Ericsson Experia X1 the first time.
on Jan 27, 2011 • Cell Phones
I want to reset the s health app on my sony experia z3
  • you have to do a factory reset and download the new app and also you can update your application
How do i factory reset my sony experia z1s phone?
go to security settings then find restore factory settings.
Sony experia hard reset
Hi James,
I have this site for you which is a forum on how to reset Sony Experia phones ( hope one that is the model of yours ). Hope it helps.
Xperia SP hard reset problem Support forum
Apr 30, 2014 • Cell Phones
1helpful
Slow android response on xperia acro S
check for any software updates available.
if any update to the latest version..
u can try to install clean master on your phone then remove junk files..
if the above steps do not solve your problem then factory reset your phone but before that make sure you have a backup of everything on your phone
1helpful
2answers
Forgot pass code for android go phone
Hey Hi. I had faced this problem and i was told to Press emergency call in idle mode.and input star key ,nine eight three star key nine eight seven pound keyit will go to the factory reset interface and reset the handset to Default and yea do not forget to update the data so that your personal information will not erased Gud Luck
How to update sony experia p
read this SONY, S/P/ACRO uses the same update solution.
http://forum.xda-developers.com/showthread.php?t=1834291
Album on sony ericsson experia not working
It look likes a software problem in your phone.
Just factory reset your phone and format your memory card, after doing all this you can use your album feature
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
