Question about Dell 1815dn All-In-One Laser Printer
Cant scan via network?
Hello, i have a Dell mfp 1815dn.
I have it connected in a small network, the network consists of one Vista and Xp computer.
Now its (the Printer) only used by the Vista computer.
My problem is to scan via network. And what i have been trying to do, is to scan from the Dell scancenter program that follows with the printer.
The printer is functioning for prints and i can find it when i use the network scan function. But when i start Dell scancenter paperport it tells me the printer is not connected.
Another thing that might have something to do with the problem is that i cand see the printer among my network overview. The upnp function is turned on, so i can see it from my xp, even if i havent installed it there yet. I can also access the web page on the printer from my vista computer.
I have installed the new firmware and am also using the latest driver for the printer.
Can someone please help me?
Sincerly yours
  • Anonymous Jan 16, 2009
    Connection between the computer and the scanner gets often borken in the middle of scan. Sometimes restarting computer, restarting Dell 1815dn and reconnecting USB cable helps for a while. Printer works, scanning to USB works (only in B/W in PDF). USB cable not too long not running in network mode.
DJSting... paperport can be used for network scanning, as it works with the dell 2335.  Now are you saying that this printer (the 1815) is limited?
Posted on Jun 23, 2009
    New Friend:
  • 35 Answers
You cannot use the paperport software to network scan. The paperport software is looking for a driver that is not installed. Network scanning for this printer is basically just file sharing. You initiate the scan at the printer itself. It scans the image and puts it on your computer. After it is there, you can use paperport to convert it to text if need be.
Posted on Jan 30, 2009
How can I get it to print the ip address to hook it to my computer
Dell Laser MFP 1815dn configuration page
To print a configuration page (also called system data report) from a Dell Laser MFP 1815dn printer:
- Press the right arrow button until Menu is the active choice on the screen
- Press the check mark button to select it
- Press the right arrow button until Reports is the active choice
- Press the right arrow button until System Data is the active choice
Aug 21, 2015 | Dell Office Equipment & Supplies
Dell 1815dn Fax confirmation?
1. restart the system ,
2. turn off the power / scan/ fax ,
3. unplug all the cable to the system and wall socket and then wait for 20-30 seconds .,
4. connect all the cables and give a try it should work.
Oct 20, 2014 | Dell Printers:Dell MFP Laser Printer...
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
I have a Dell laser mfp 1815 dn. There is not an option to scan to a pdf. It will scan to a bitmap which is not what I need. How do I get it to scan to a pdf?
When you save the scan select pdf from the pull down menu "Select Type of Document" in the Save Dialog.
Hope that helps.
Jul 23, 2011 | Dell 1815dn All-In-One Laser Printer
My laser mfp 1815dn is reducing the size of the image of the document i am scanning. how do i get it back to scan and save a full page?
Welcome to Fixya!
Adjust the Scan setting to the defalult/appropriate resolution. See guidelines below.
300 dpi black-and-white or 200 dpi grayscale or color
Documents of poor quality or that contain small text:
400 dpi black-and-white or 300 dpi grayscale
Photographs and pictures:
100-200 dpi color or 200 dpi grayscale
Thank you for using Fixya. Have a great day.
Jul 12, 2011 | Dell Printers:Dell MFP Laser Printer...
I have dell mfp 1815dn printer and when i give the command for printer or copy the display shows NOT AVAILABLE
make sure the interface cable which connected to your system is good, if the problem persist then re- install the proper device driver.
Apr 05, 2011 | Dell 1815dn All-In-One Laser Printer
How to unlock a dell laser MFP 1815dn
You may want to try the following:
There's a little blue toggle switch where the copies/scans come out from.
Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back o
I hope this helps.
Good luck!!
Mar 01, 2011 | Dell 1815dn All-In-One Laser Printer
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815 network scan problem- can print but not scan or see it
Pl. check your internal system ip address, take the configuration sheet of the printer to know its address and use it and should not match with other.
Apr 18, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
1,585 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
