Question about Bissell 6594 PowerForce Bagless Upright Vacuum
My Bissel powerforce vacume filters
A friend of mine gave this vacume to me when she moved and i am greatfull but she did not give me the hand book and i can not figure out how to remove the filter that is under the dirt catcher. Can anyone help me?
Remove the lower half of the dirt bowl by turning counterclockwise. Turn the filter counterclockwise, remove the foam filter and clean both with soap and water.
Posted on Aug 29, 2007
My Bissel powerforce 6596 has suction but the dirt is not making it into the dirt cup. If I shut it off, the dirt drops to the floor. Also the motor seems to be over heating. All filters are clean. I...
Just because you cant see the obstruction doesnt mean theres not one. The hose could be stopped up somewhere not visible to your eyes. I have one and I have to take hose off and apart to clean it out. check the roller. Is it rolling?
May 17, 2011 | Bissell 6594 PowerForce Bagless Upright...
I purchased my Bissel PowerSteamer Clearview a few years or so ago, and cannot find where I filed the manuals. If I find the actual seriel number on the Bissel PowerSteamer Clearview, Is there a way that I...
No need my friend. Go here. All documentation is here...and....it's free! Hope this helps : )
http://www.bissell.com/user-guides/?searchtext=1699%2520pro%2520heat&searchType=search&mode=228
Jan 07, 2011 | Bissell 1699 ProHeat Clear View Upright...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
How to open the inner and outer circular filters
Hello, please open this link and refer to pages 8 and 9 thank you
Let me know if this answers your question at
bsix@hotmail.com
http://www.bissell.com/images/UserGuides/6584_1008.pdf
Sep 04, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissel vacuum
take the dirt cup out and turn the bottom of it that will let you get to the filter,there should be some finger twist plates on the top,turn and take it out,there will be a foam cover around the filter,take that off and clean with warm warter,when done towel dry with paper towels,now the filter itself is water friendly ,take a brush and in up and down strokes ,clean while running water over it.above where the dirt cup goes is another filter ,just reach up inside and twist and it will come out,clean that also.now put the dirt cup back in without the filter and see if you have suction,i believe you will.let the filters dry before you put them back in then reassemble,and if that don't work, the take the hose off and see if you can blow through it .if thats not it then at the bottom on the right you will see a clear hose,thats your intake hose.there is a screw on the black fitting thats connected to it ,take it out and get you a coat hanger and bend the tip so its rounded ,thats so you don't puncture a hole in the intake hose.work the hanger down into the intake hose and push out the clog .then try it again..please leave feedback.i hope i was some help to you.iwould clean the foam filteres at least once a month
Oct 01, 2008 | Bissell 3522 PowerForce Bagged Upright...
Overheating
check filters and for blockage - poor air flow then will overheat
Aug 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
REPLACEMENT FILTERS FOR THE POWERFORCE 6 BAGLESS VACUM.IS THERE A BISSELL STORE IN THE DETROIT MICHIGAN AREA I CAN FIND BISSELL BELTS FILTERS ETC.
Here are Bissel's numbers, they can tell you who to contact.
Service Center Dept. Phone Number:
(800) 457-1509
Service Center Dept. Fax Number:
(800) 517-9535
Hours:
M-F 8:00 a.m. - 5:00 p.m. ET
Aug 10, 2008 | Bissell Vacuums
Bissel model 6579-3 powerforce
You can download the user manual as a pdf file at www.bissell.com. Just type the model number in the search box.
Apr 13, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
102 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
