Question about Acer Aspire 5600 Series 5630-6951 Laptop
Cant turn on wire less e net on
Is there a key to turn it on . thanks
  • 36 Answers
There should be either a switch on the side of your laptop for turning your wireless on/off
or...
look at your f1-f12 keys. there should be a picture of what looks like a wireless icon on one of these. you can then turn the wireless on or off by holding the FN key and pressing the F key you see the icon on.
hope this helps
Posted on Jan 16, 2009
My 2005 Suzuki Aerio won't start. I know that there is power as the lights, radio, ect are working when the ignition is turn on, but the car will not turn over. Side note, the heater blows even though it...
IS tthis a DIY question? or just want guessing? ill pretend DIY/.
no, the car will not crank.
cranking uses 100 amps of current,
the HL , maybe 10amps, 10x less.
turn over means nothing, cranking matters
both the starter and engine spin, "turns over": (1 can and other might not)
starting is a whole other matter, as is sustained start, called running.
crank?> start, started, running, 1,2,3,4.
the heater blower runs, key on, but the heater switch is off.
seem like the controller is tad upset, (lets fix engine first) and fix blower later. (my bet is it wakes up when battery is happy)
my guess is car has and automatic transmission, right>?
and as such to crank it must do so in, park and in Neutral.
does the engine crank in NEUTRAL. (hold foot brake, keyon, shift th N. ) crank now?
1: check fuses yet?
2: check rested battery voltage yet (meter) 12.6vdc.?
if less battery is bad, or only discharged. if yes, charge it?
no charger use jumper cables to crank car. got cables?
call AAA tow they jump start it? no AAA?
barrow a charged battery and try that, ok battery is charged and it will not crank,,, ,good progress now.
3: i next hot wire the starter solenoid. (some cars this is very hard)
check for about 11vdc at starter key line cranking.
0v means its dead.
hot wire that small starter wire, there, cranks now , key off
the starter is good.
now check voltage at the left side of P/N switch, Park/neutral.
12vdc id good, cranking, 11 is too.
if you cant get at least 11v out of switch 20. that means
the P/N switch is bad, (11 or more input)
(battery is good, solved that in test 2)
so bad transmission park neutral switch called the KEY line.
Feb 28, 2015 | 2005 Suzuki Aerio
Which switch will turn on the wireles net connection
The keys along the top ranging from F1 to F12 will have icons on them. you will need to locate the icon that resembles a WiFi tower or radio signal.
By default the F1-F12 keys are inverted performing their functions such as turning WiFi on and off so the Fn key will not need to be pressed unless you have changed this setting (typically in the BIOS). If pushing the button with or without the Fn doesn't turn your WiFi on and off then you may be missing the software needed for this to function correctly and you will need to visit Dell to download applications related to your wireless.
Nov 28, 2011 | Dell Inspiron Mini 1012 Netbook...
I have not open wi fi wire less net work . But wire less net work LED is open
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 13, 2011 | ASUS Eee PC 1000HA Notebook
I now receive my router !it came lime service!when i hook it up to the computer it will not work ! when i try to used the wireless it keep telling me !mis match pass key ! too would not work !call the...
There is two pass key's one for the service provider and the other is for the wireless connection between your laptop and the router.Read your manual.
Feb 17, 2011 | Computers & Internet
I cant get my logitech desktop ex 100 keyboard to connect, but the mouse does...anyhelp would be appriciated thanks
we should keep battery in mouse and key board. we get three thing . mouse key bord and usb conneter or usb wire less relay. when we keep it on usb port of computer mouse and key bord auto matic detected we seeon screen ( nepal)
Oct 11, 2009 | Logitech Cordless Desktop Ex100
I have a chevrolet malibu 2001. I cant turn on the car.
i had the same problem is that you need to change the ignition of your car. let me know if that work
Jul 15, 2009 | 2001 Chevrolet Malibu
It's possible to use the web cam in the lap top toshiba satellite 210cs and how?And it's possible to get acces to the wireles net and how?
hi...the answer the web cam is yes...u can do try input the USB web cam and install the CD drivers...the answer about of wifi/wire less internet Yes..if u have wire less LAN u can do it try to access find the switch button on side the body of unit..if u have no wire less LAN u need to buy wi fi/wire less LAN for laptop..thanks abd good luck..have a nice day..^_^
May 17, 2009 | Computers & Internet
I cant seem to change back to my admins
Have you tried::
  • Windows key + "R" less the quotes;
  • in the Run window, type "cmd" less the quotes;
  • Ctrl + Shift + Enter instead of pressing Enter or OK button;
  • in the Command Prompt window, type "net user Administrator /active:yes" less the quotes;
  • press Enter;
  • try switching user or reboot if necessary.
Pls post back result(s).
Jan 09, 2009 | Microsoft Windows XP Professional With...
Windows 98
Windows98 does not support USB.
More detailed info is needed to help wth your wireless problem.
Dec 28, 2008 | Microsoft Windows 98 for PC
Cant get thelaptop to work and very fustrating
u need to first configure teh wire less on the router>go to the main computer>and open browse window and and in teh address bar type- 192.168.0.1 hit enter u can see login screen
user name-- admin lower case or blank
password-- admin lower case or blank or password
and u can see the set up scren and select wire less setup in the left side and follow this
Wireless Settings Wireless Network Name (SSID): Region: --- Select Region --- Africa Asia Australia Canada Europe France Israel Japan Mexico South America United States Channel: 11 Wireless Access Point Enable Wireless Access Point Allow Broadcast of Name (SSID) Wireless Card Access List Security Encryption (WEP) Authentication Type: Automatic Open System Shared Key Encryption Strength: Disable 64bit 128bit Security Encryption (WEP) Key Passphrase: Key 1: Key 2: Key 3: Key 4:
Nov 18, 2007 | NetGear WGR614 Wireless Router
Acer Aspire 5600 Series 5630-6951 Laptop Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
