Question about Pioneer SX-315
Power shut of after 10-30 seconds
But i will come bak on when i click the power. Can someone slove this problem
  • leeperhenryr Jan 15, 2009
    YES THE POWER COME ON BUT IT CLICKS OFF AGAIN
    New Friend:
  • 111 Answers
Power amp output section faulty.can you open the cover and listn the relay turned on while problem occured.come back after observation.
nuwan
Posted on Jan 15, 2009
  • nuwan chinthaka
    nuwan chinthaka Jan 15, 2009
    i think set going to stanby because of faulty output tansistor or ic.
    is the power amp IC or TRANSISTOR driven?
    nuwan
How do i shut my acer chromebook down after use please
Power off your Chromebook To turn off your Chromebook completely:
  • From your desktop, click your account photo, then click Power .
  • Click your account photo, click Sign out, then click Shut down.
  • Press and hold the Power key for three seconds.
Jun 09, 2017 | Acer Computers & Internet
When the computer turns on it says.... " Application explorer.exe encountered a serious error and must shut down. Just purchased the computer and it will no go pass this error message
"Application explorer.exe encountered a serious error and must shut down"means sometime in the past, someone must have installed the OS incorrectly or has deleted something vital, which is why this error is occurring. The only way to bypass this is to reinstall windows OS using the CD that was provided for you, and this error will disappear.
Jun 29, 2011 | Sylvania G-Netbook
All of a sudden my computer shut off n then wen tryin to turn it bak on it wouldnt let me use my mouse of keyboard ive tried reinstalling xp and it never fixed and system restore never worked either the...
You probably should see if the driver for the mouse and keyboards is properly installed if that's all your having problems with. Go and re download the drivers from the website and see if that doesn't work.
Mar 01, 2011 | Acer Aspire 5670 Notebook
Why sometimes i shut down my window but the word "shut down" keep appearl and cannot finis shut down...
Then, you should keep on pressing 'Enter' on the keyboard, perhaps it will finish shut down...or you
can turn off the power link, this is a silly question that you have made but i am glad to slove this to you. :)
Jan 21, 2011 | HP Mini 1000 Netbook
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
My emachine pc wont turn off. when i shut down the stanby lights and fan is on
hold the power button for 6 seconds it will turn off..................sounds as if someone has set the power options to standby or sleep instead of shutdown......if using xp right click on a blank space on the desktop and go to properties next go to screensaver tab then power tab finally go to the advanced tab look to bottom of page power button options dropdown make sure it is on shutdown if not change and apply settings then hit OK.
Jul 21, 2010 | E-Machines Computers & Internet
My Samsung CD-RW/DVD-ROM Combo Drive could not support dvd ?
try these steps
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Jul 05, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Shuts off after 15 seconds
sounds as if the magnetron has gone bad.this part of the machine is still under a warranty,and you need to call for a service technician to look at it.
do not use the unit until you get someone to look at it and or replace it.
Jan 31, 2010 | Panasonic NN-SN657SMicrowave Oven
Total power loss
Check the battery connections. Also check the connection of the cable at the underhood fuse box where there is a "stud" with a cable that looks like a small version of a battery cable secured by a nut. Hope this is helpful.
May 23, 2009 | 2007 Chevrolet Cobalt Coupe
Mitsubishi vs-4543
Most likely the convergence output IC has shorted out and has overloaded the convergence power supply, which has stopped working. The computer senses that the convergence power supply is not running and shuts the set down. The convergence IC should be replaced, the power supply restored and the convergence circuits realigned by someone experienced in Mitsubishi projection sets. When I do a housecall for a set like that I charge $150, but shops in your area will vary so ask around.
Aug 04, 2007 | Mitsubishi VS-4543 45" TV
Pioneer SX-315 Logo
130 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
