Question about Symbol LS2208 Handheld
LS2208 beeps to ignolage the scan but puts no information
When I scan barcode the scanner beeps but puts no information into application. Reset scanner to defaults and scanned the configuration codes from manual but no success. The light is blinking continiously after the scan. Seems to me like it retains information in memory but not transmitting cipherlab
  • mal626 Feb 20, 2009
    hello I am having the same problem. How do you reset the scanner???
I don't know if this applies to the LS22208.
Symbol Support FAQ says;
A slow continuous flashing LED on the LS9208 indicates that the LS9208 has been put into “programming mode” and is ready to scan programming bar codes. Once the LS9208 is correctly programmed, the LED should stop flashing and remain on, indicating that the scanner is ready for use.
A fast, continuously flashing LED on the LS9208 indicates an internal problem. When the LED is in this state, the LS9208 laser is also shut off for regulatory reasons.
We support these for some big retailers. When they call with that issue 99/100 it's reseat the cable from the base of the scanner (or the system if accesible), no re-programming).
Posted on Jan 16, 2009
    Problem Solver:
  • 19 Answers
Do you currently have hand-held inventory scanners?
Although you may not be familiar with Legacy's Technology Services, we may already be servicing your barcode scanners, barcode printers and even POS hardware. Many sellers of extended maintenance contracts have used Legacy for years to perform service on devices covered by their contracts.
Maybe you're looking for a specific hard to find part. Chances are I've got it!
We also carry refurbished equipment if you are in the market.
Give me a call for a quote and to discuss your current needs.
Joe Anselmo
Legacy Technology Services Inc
(847) 621-3300 ext. 418
Email: janselmo@legacyglobal.com
Posted on Apr 13, 2009
  • 33 Answers
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Posted on Jan 15, 2009
Im trying to get my ls2208 scanner to read comic book barcodes its 13 plus the 5 digit extension can i get some help with this. im running windows vista 64bit not sure if that matters or not.
Just take a Print out this PDF file and Scan the Barcode
1st u need to scan the enable Interface Barcode then Scan Any barcode Length
Cheers
Hope its solves
Sep 05, 2011 | Symbol LS2208 Handheld
This will probablly be the dumbest question that can be posted here, sorry I'm a newbe to this. I was just given a Symbol Tech LS2208 scanner. I have downloaded and installed all the software and...
The LS2208 acts as keyboard, so whatever you scan should be directly written to your Desktop PC application. If you installed the 123Scan2 Application, you would need to quit it to start using the scanner. It is an Application to create and save the settings, but it should not run during scanning.
Aug 15, 2011 | Symbol LS2208 Handheld
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Nov 02, 2010 | Symbol LS2208 Handheld
Ls2208 Barcode Scanner program for .NET
here is the Barcode Scanner Program right now, it seems like being able to scan barcode with Symbol Ls2208 handheld device.
if it is not workiing, go to this barcode website to find more compatible software for Ls2208, i am sure you will find the proper one.
NET Barcode Reader Barcode Reader ASP NET Barcode Reader VB NET Barcode... Barcode Components NET Barcode Generator Reader Java Barcode Generator...
Jul 28, 2010 | Symbol LS2208 Handheld
Reversing first 2 digits of barcode
Attached are the programming barcodes for the LS2208 solve this problem. Print the attached file and scan the barcodes in order 1-10. This will only work on a LS2208. If you scan the Set Defaults barcode it will erase this programming rule.
there is a document you will need to scan to do this, if you want to send me an e-mail i will send you the document
kganoe@datexcorp.com
Mar 13, 2010 | Symbol LS2208 Handheld
LS2208 scanner not returning for multiple scans
It sounds like you need to program a Tab after each scan. You will need to download the manual from www.motorola.com so you can access the setup bar codes.
May 27, 2009 | Symbol LS 2208 Barcode Scanner
4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Apr 14, 2009 | Symbol LS2208-7AZK0100S Handheld
Any way to lower the beep sound ...
this are all barcode to solve u r problem.......
please tell me how to set prefix /suffix values ?
i have already set scan prefix & scan sufix and then scan option ...
but did not get the< prfix ><data>< suffix> only data will retrive...
prfix value is `key, suffix value is Tab !
please help me
Feb 04, 2009 | Symbol LS2208 Handheld
Symbol LS2208 RS232
Go to the LS2208 quick start manual scan the "Set Defaults" barcode and it will return the handheld to factory default.
Jan 31, 2008 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
1,148 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
