Good day sir im using asrockp4vm800 with processor intel celeron 2.40. i need the driver kindly sent my email
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    What driver?
    Chipset? Audio? Modem? NIC?
    Problem Solver:
  • 16 Answers
I need intel celeron 2.40ghz vga driver software i lost the motherboard hard copy
you need to give details of the motherboard you are using, add the make and model and resubmit the query. There are no graphics drivers for celeron chips
Nov 16, 2013 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Want intel celeron drivers
Try here. The site requires more input to filter download. Good luck.
Sep 22, 2012 | Intel Celeron M, 1.3 GHz Celeron M (SL6N7)...
Sir, In my system motherboard model is D101GGC. my question is can i replace porcessor pentium 4 with the Core 2 Duo
Sorry but you can't. It is not compatible. You can install Pentium D processor instead, if you want to.
For the list of compatible processors for your motherboard, you can check it here:
Thanks for using Fixya!
May 31, 2011 | Intel D101GGC Motherboard
I need emachine etower 600is intel processor
The eMachines eTower 600is uses an Intel Celeron III processor that operates at a maximum frequency rate of 600MegaHertz. (600MHz)
The Intel Celeron 600 uses a Socket 370 processor socket.
There is a locking arm on the side of the Socket 370 processor socket, that is unlocked by easing the arm over to one side to clear a lock tab, then the arm is lifted up to remove the processor.
Example of a Socket 370 processor socket,
The eMachines eTower 600is uses an Intel 810 chipset, for the motherboard chipset.
[Chip and Chipset are slang terms used for Integrated Circuit, or IC]
The Intel 810 chipset, supports processors with a 66MegaHertz Front Side Bus. (66MHz FSB), or 100MHz FSB.
In an additional link, I will give a recommendation of where to buy an Intel Celeron 600, that uses a 66MHz FSB.
I'm not advertising for this place, it's just a place I have used, and have had good results.
Also information on the Intel 810 chipset.
You could also use an Intel Celeron 700MHz processor, but better still you could use an Intel Pentium III 933MHz processor.
Pentium's typically have Two times, the L2 cache that a comparable Celeron has.The more L2 cache a processor has, the faster it's going to process information.
I also know it will work because out in my shop I have an eMachines T1090, that has an Intel 810 chipset, uses a Socket 370 processor socket, and has an Intel Pentium III 933MHz processor in it.
(Made in 2001, and still works good to this day)
The Intel Pentium III 933MHz processor uses a 100MHz FSB.
The Intel 810 chipset supports processors that have either a 66MHz FSB, or a 100MHz FSB.
If you are not familiar with computer hardware technology, then I have just thrown a whole lot of information at you that is unfamiliar.
Should you like me to break down the information, I would be glad to. Just state so in a Comment.
Mar 22, 2010 | E-Machines etower 600is PC Desktop
I have p4 3.06 ghz processor on mother board it is written P5P800-vm/s i require VGA and sound drivers(realtek ac97 sound driver} i have i P5P800 VM motherboard and i was wondering if i can upgrade it's...
NO. you cannot install DUO to *********** board. the DUO is pinless and the P4 3.06 is pin type if you want to upgrade your PC you have to replace the mother board too.
May 18, 2009 | ASUS P5P800-VM Motherboard
Compatibility Intel Celeron 2.66, ECS Elitegroup P4M800PRO-M3,
what is your motherboard name and version, send me your total computer quoation on my email address below...
good luck
Apr 12, 2009 | Intel Celeron, 2.6 GHz...
Hi have tried everything!! my windows media player 10 will not recognise my intel celeron d inside driver for windows xp, what do i do??? im not that experienced, but have tried everything!
The Intel Celeron D Inside Driver? Windows XP is designed for the Intel Celeron Processor and does not require a driver. Window Media Player 10 however requires a valid copy of Windows XP with SP2... If you go to the Windows Update website it should upgrade your PC and the version of Media Player for you.
Nov 27, 2008 | Intel Celeron -D 2.26Ghz Computer System...
Upgrading my laptop's processor from celeron 540 to 560
Fan cooler for Celeron is usually the same for 540 and 560 Ghz, there should be no need to replace cooling system if you pass from 540 and 560
Whenever you operates on CPU and cooling system you need to monitor CPU temperature using Bios or a dedicated software. Here is a good software to check CPU temperature and Fan activity: SpeedFan Download.
Regarding the RAM, some seller like this one (UK seller).sells Trascends 2 GB modules, seller says they work on 4315, you can eventually ask them if there is any issue with bios version and if you need to upgrade bios.
Remember, CPU upgrade on a laptop is not a simple operation, be careful if you do it yourself, as it is easy to damage the laptop when taking it apart. Regarding RAM, main risk is incompatibility, If you live in UK the seller above guarantee compatibility with Acer 4315, double check by sending them an email before buying.
Aug 11, 2008 | Acer Aspire 5100 Notebook
Hello ERION,
this is your lucky day... we both have the same make and model of motherboard. i downloaded mine on the link below.*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
you can find all the drivers you need in this link.
hope you find this post helpful... :)
Jul 30, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
