Question about ViewSonic VA1703wb Monitor
Half monitor display and other half will be some different color.
After switch on the monitor, it display Half of the monitor correct and other half will be some mixcolor.How set up this problem
  • 30 Answers
Click -Start then Ctrl Panel - then Display - then Settings...
make sure you have 1280 x 800 (32 bit) .
or just hit the default tab .
Posted on Jan 15, 2009
  • Marc Bradley
    Marc Bradley Jan 15, 2009
    could also be a driver issue, or a bad video card test each in turn.
Hi. I had a similar problem with 1/4 screen black, 3/4 screen white. My solution:
I opened Control Panel, then clicked on Display and then on the Desktop tab.
Then I opened Customize Desktop and then clicked on the Web tab.
If the check box beside My Current Homepage has a check in it, click to uncheck that box.
Then click OK twice successively and your monitor should now be one desktop color.
If the My Current Homepage box is not checked, then I don't know what the solution is.
(My problem was that I had checked the box to display My Current Homepage, but I had not provided a homepage to display.)
Hope this helps.
Posted on May 21, 2009
Why is my screen opening at half screen?
not sure what half screen you are referring to
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
or if its actually half of the screen
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Aug 09, 2012 | HP Computers & Internet
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
My Acer AL1916W LCD does not show full color. The half of the screen show one color while the other half display normal color that am expecting. I don't know how to correct it. I have use the setting...
More likely to have failing T-CON board which is part of the LCD panel assembly, you can try reseating the ribbon cable attached to the LCD panel's T-CON board first, otherwise new panel will be needed.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
Montior screen is half shaded and half bright
Do this to check if your monitor is in working state or not...!
Step 1:- Turn on your computer.
Step 2:- Unplug the Video Cable of your monitor which is connected with the computer.
( Video cable:- Cable going from the back of your monitor to the back of your tower. It has a plug with two screws on the plug ends, which you can unscrew to unplug it. Thats how it looks like. Some times it is in grey in color some times in blue.)
Step 3:- Now check on your monitor. If the display says " No Input Signal " :- your monitor is fine. Some thing wrong with the computer graphics.
If there is not display and the monitor light is blinking or solid the monitor has gone bad.
( Note :- Remember when you unplug the video cable do not unplug the power cable of the monitor. )
Let me know if it helps.
May 18, 2010 | Computers & Internet
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
Monitor is showing bottob half display and upper half is blackout
Hate to say it, but time for a new monitor... will cost you WAY more to fix than to pop-by a garage sale and grab a new monitor.
(It's not even worth a repair-persons time to do it...)
Aug 31, 2009 | Philips 105S51 15" CRT Monitor
Bottom half of monitor displays top half of desktop
You could try a different resolution for the monitor.It's possible the monitor cant support the resolution your trying to display your desktop at.
Jun 01, 2009 | ViewSonic GS773 (White) 17" CRT Monitor
Half of monitor screen shows on the projector.
You will need to set your computer to the correct display properties.
This you can do by either going to presentation mode.
Alternatively,
on Window XP you can simply go on to your desktop and right click > go to properties>go to setting> press display 2 and set the screen resolution as per your projectors resolution and enjoy.
( for information: display1 is the resolution meant for your computer).
Please do rate this solution and Thanks for usinf FixYa!
Mar 12, 2009 | Toshiba Office Equipment & Supplies
Text color is not consistent on Acer 191 monitor
THE SITTINGS MAYBE ON THE SIDE OF THE MONITOR HALF WAY DOWN OR HALF WAY UP. MODE OPTION, ACER MAY ALSO REQUIRE A SOFTWARE SETTINGS ALSO JUST NOT SURE WITH ACERS SETUP
RODGANDYSR
Mar 07, 2009 | Acer P191WBD LCD Monitor
2001FP LCD Half Display
please refer to this link for help..
http://support.dell.com/support/edocs/monitors/2001fp/EN/trouble.htm
Sep 09, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
ViewSonic VA1703wb Monitor Logo
1,116 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
