Boot Loader Problem in working with two O.S
I Have working with two operating System window XP and Mandriva  if  i remove any one operating system from hard disk there are bootloader are not available i have lost second operating system also so please help me how can i protect my second operating system when i remove my one of the operating system. .......
  • oposit
    oposit May 11, 2010
    What bootloader are you using?
  • Vanja Djuric
    Vanja Djuric May 11, 2010
    how do you know you are going to lose both? :S
    that should not hapen...
  • 42 Answers
Which OS you erased first and how did you erased ?
Reinstall XP first, it will format the disk (be sure to back up all your files first). Then install Mandriva, it will detect XP and will ask you if you want to install it next to XP so you can have both or if you want to use the entire disk for Mandriva.
Posted on Aug 26, 2009
Dual boot xp with windows 8
No solution now, Install Windows XP again on first partition, Make sure BOOT.INI, NTLDR, NTDETECT.COM in the same partition in which Windows XP is loaded. Then install WIndows 8.
OR in the current scenario you've to do much technical work using third-party tools.
Feb 27, 2014 | Microsoft Windows XP Professional With...
There is only one OS, but during booting it shows three
Delete the OS Command line inside the MSConfig indow by clicking start - run -type msconfig then press enter. On the MS config window click on the boot.ini tab then you will see the command line inside the text box. Leave the first command line from [Boot Loader] till the end of the command line of your Default Operating system.
Example:
(Leave this lines)
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
(Till here!)
(Delete this line)
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Viz XP Example line Professional" /fastdetect (up to here)
any other command line that says Viz XP -- you may delete it. Click apply button then Restart the computer afterwards and this should fix the issue.
Should you have any other questions just please leave a comment.
Cheers~
Jun 28, 2010 | Intel D845GVSR Motherboard
Ntldr is compressed or ntdrl and my xp wont boot
ntldr is telling you the boot loader is not present.
reinstall the operating system or try to copy a MBR from a working computer with exact same operating system.
Apr 30, 2009 | Microsoft Windows XP Professional SP2
Boot Loder Problem when working with two operating System
best practice it when installing windows and linux install windows first and then linux. GRUB or LILO boot loader is much better then windows boot loader and very easy to reinstall. Mandriva cd should have a rescure feature that will allow you to reinstall the boot loader.
Jan 15, 2009 | Computers & Internet
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
Dec 28, 2008 | Microsoft Windows XP Professional
BOOT.INI deleted. How to re-create this file?
timeout=30
[operating systems]
Please rate this if you found this answer helpful. :)
Booting
the following id taken from my own XP media centre laptop.
line 1 [boot loader]
line 2 timeout=30
line 3 default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
line 4 [operating systems]
line 5 multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
ignore the "line 1,2,3 etc" I added them for clarity the formatting in this answer pane messes up the last line.
also before you get to edit the start up file make sure that the default operating system listed is the sae as line 5 starting from the "
hope this helps.
Nov 08, 2008 | Microsoft Windows XP Media Center Edition...
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Sep 12, 2008 | Acer Aspire 3680 Laptop
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
