Question about Encross KR-400T 40 in. HDTV-Ready LCD Television
Screen goes black after 30 minutes
Requires you to turn it off for a minute and then turn it back on...it then goes out again after a few minutes
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Dear Madam/Sir - I have a Grundig Xentia 26'' LCD TV that is 4-5 yrs/o. Recently, when we turn it on, the picture comes on OK but in a few minutes the screen goes black. If I turn the power off at the wall...
Ur backlight video board,dying.Well require changing keep happening.LCD require more power and floescent lights more heat,not like cathoray tube have radiation,but more glass take heat better.
Nov 25, 2009 | Televison & Video
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
Screen goes black after 30 mins of working.
There are a few things you need to check here.
1. It could be that your computer power management is set to turn your monitor and harddrive off after 30 to 45 min.
If the computer is however working for 30 to 45 min while you doing stuff and it shuts off, the there is an internal problem "Hardware"
I would suggest you check to see if the power management is set to turn off monitor 30 min and harddrive after 45 min. IF that is not so, then we go on to the next test.
It could possibly be your processor fan is not working so once your processor gets over heated it shuts off the computer.
Turn off the computer, remove the case "this is only if you know what you are doing" with the case off, power on the computer and see if the processor fan is working.
You can get back to me and I can walk you through it.
Hope thiss help.
Aug 23, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
Apr 30, 2009 | Sharp Aquos LC-C3234U 32 in. LCD TV
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Black screen
Most likely suspect would be a bad solder connection. The connection heats up and becomes an "open" circuit like turning off a switch, and then as the set cools down the connection "makes" again allowing the set to come on. Parts should not be required as I consider this brand to be a "disposable" TV.
Dec 10, 2006 | Apex Digital GB4308 43" Rear Projection...
Encross KR-400T 40 in. HDTV-Ready LCD Television Logo
61 people viewed this question
Top Encross Televison & Video Experts
Are you an Encross Televison and Video Expert? Answer questions, earn points and help others
