Question about Olympia 1500.1C HS Shredder
Shredder Errors before Paper Touches Blades
Our office has an Olympia 1500.1C. We received it through GSA about 2 months ago. on 13 Jan 09 it worked fine, but on 14 Jan 09 it errored out when you tried to shred paper. It will run in reverse fine. We have vacuumed everything that we could. It was oiled on a regular basis.
  • anthonyzig May 11, 2010
    Do you have an automatic oiler on this equipment or are you manually oiling it?
  • 219 Answers
When the paper shreds it pulls both the blades inward. Reverse spins them outward.
There must be something too large between the blades because it can be pushed up just not pulled down.
Has a staple or paperclip been inserted into the machine?
Try one of these two things:
When you're vacuuming the machine, hold the reverse button in and see if that helps.
Unplug it, take out all loose pieces like the bag liner, tape the door closed, get another individual to help you flip it upsidedown and GENTLY tap the machine to break free any obstructions.
Hopefully one of these solutions will work for you.
Posted on May 27, 2009
Not sure of the model number but my paper shredder was purchased on Jan 16 of this year and quit working the middle of July except for the reverse mode. I need help.
no
we don't sell anything
there is something stuck in the blades
in the middle of the cutters there is a small plastic lever that is the micro switch for the forward action . paper is stuck and that lever is now not operating the microswitch to drive the cutter motor
either that or the lever has broken off, again not activating the micro switch
If you want repairs or warranty , contact the manufacturer direct by phone
Aug 17, 2016 | Omnitech 12 Sheet Cross Cut Shredder
When bin was full, I emptied it only to find that my shredded no longer worked on auto, forward or reverse
Dear Sir,
Maybe, just maybe, I have an answer for you.
Somewhere on the part of your shredder that touches the bin, there is a tiny switch that touches the bin, and it is a safety switch that causes the shredder to stop working if the bin is removed.
In the shredder I have, and have had, the switch is usually plastic, and is the same color as the plastic body of the shredder.
Proper positioning of the bin to the "bottom" of the shredder is critical to it's working, as the bin presses on the switch to "close" it.
God bless your efforts.
May 09, 2016 | Techko SH1524CP Shredder
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Feb 20, 2012 | Royal Sc120 Shredder
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Our Olympia paper shredder forward switch does not work but the reverse does.
Move the power switch to AUTO (l) position and depress the manual forward button for five seconds to clear paper blockage. Make sure the paper is engaging sensor located in the center of the shredder opening.
Good luck..
Apr 15, 2011 | Olympia Office Equipment & Supplies
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
    Instructions
    Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
    Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
    Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
    Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
    Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
    Good Luck!
    Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
    Takes the paper and then it backs up
    This happens when the shredder detects an overload or potential jam condition. try making sure the cutters are lubricated with the correct machine oil and it will take paper in correctly. Experiment with feeding in different numbers of sheets to see what it is capable of. Avoid paperclips and stapes as they can damage the cutters and force the cutting blades to become misaligned which in turn puts additional stress on the motor and will mean that you will be able to successfully shred less paper than if the blades were OK and in good condition.
    Oct 07, 2009 | Olympia Office Equipment & Supplies
    Olympia Shredder Jammed and not working
    likely a spacer has broken, if you can see the underside of the cutting heads you will see a spacer or two hanging out, If this is the case the heads will have to be bebuilt or replaced.
    Mar 06, 2009 | Olympia - 1452C CROSS CUT OFFICE SHREDDER
    Olympia shredder 1280.6
    On this model, make sure the hopper is all the way in. If it is, remove paper hopper and check to make sure the hopper is not broken. There is an electromagnetic switch in the front and the hopper has a magnet built in to it. run a stick magnet across the right underside and front to see if it extinguishes the light. If not, then the board is bad.
    Jun 12, 2008 | Olympia 1280.6 Shredder
    Olympia 1500.1C HS Shredder Logo
    149 people viewed this question
    Top Olympia Office Equipment & Supplies Experts
    James Cagle
    James Cagle
    Daniel Thibodeau
    Level 1 Expert
    Jim Keysor
    Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
