Rank: Apprentice
Rating: 94%, 6 votes
Below is what worked for me:
I have the Kenmore Elite Trio French door refrigerator - this is made by LG Electronics
Based on Harvy's and others' comments, here is what I did:
1) Turn off the ice maker for 10 or more hours and remove the ice bucket - this is to give the ice maker time to thaw out if there is any ice build up. (I even used a hair dryer on the feeler arm after the ice maker was off over night)
2) DO NOT TOUCH THE FEELER (ice measuring) ARM!! - When the ice maker is making ice the Feeler arm will be UP - yes, UP!! UP means MAKE ICE.
(This the complete opposite of how many internal freezer ice makers feeler arms work. The freezer ice makers arms are up to stop ice from being made. This is not true for our freezers.)
3) Put the ice bucket back in the refrigerator.
4) Do as Harvy said: Press and Hold the Ice Selector Button. Yes, keep holding it. Keep holding. The white hard plastic "fingers" will start to rotate slowly. At one point while the fingers are rotating, you should see water quickly flow out and fill the metal ice chambers.
Note: The ice feeler arm may not move at all during this process. That is OK. If the feeler arm is in the UP position, that is even better.
5) Keep holding the Ice Selector button until the white plastic ice pushing "fingers" are COMPLETELY out of the water and ice chambers. You do not want ice to freeze onto the fingers, because then you will have another problem - ensure the fingers are not sitting in water.
6) Release the Ice Selector Button when the ice pusher fingers are free and clear of water
7) Close the ice maker door and wait for ice!
Give yourself 6 hours for ice - I say this so that you will not get too impatient to see if the ice maker is working. Also, the ice maker chambers have to cool down to make ice too.
Preventive Maintenance:
* If traveling weekly, like I did, EMPTY THE ICE MAKER and Turn it OFF!! This steps is listed in the manual for the refrigerator, If the ice maker is not regularly used, produced ice builds up around the feeler arm and may melt and freeze inside the feeler arm assembly.
* Use the ice maker! I now put ice in freezer bags or dispense them to throw at geese crapping all over my yard. :-)
* Don't turn the refrigerator temperature below 38 degrees. I did this when I first got the refrigerator and the ice maker stopped making ice. I turned off the ice maker off overnight and turned the temperature back to 38 degrees and in 24 hours I had ice again.
Hope this help. Your suggestions helped me. Thanks!!
Comments:
Aug 16, 2008
- Also, forgot to mention
akira-kodi helpful information...
