Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Can connect only one computer at a time over westell 327W modem
I have verizon DSL and am using a westell 327W modem but if i connect my laptop wirelessly me desktop pc which is hardwired will not access. If I turn off the modem and let it reset after a few minutes I can access with the desktop but then the laptop wont access and my laptop will give me false readings saying it is connected but wont let me bring up the internet saying there is a connection problem.
  • 4 more comments
  • thebleighs Jan 15, 2009
    right now on my laptop cant find in the network connections where it says about internet protocol. Im accessed wirelessly if that makes any difference.
    DUH found it it was set up on my laptop to auto obtain I will check the desktop which is hardwired in the morning, thanx I will let you know how it goes, also will it make a difference if I am accessing my network with a WII system, which I setup to auto obtain IP as well?
    alright I will let you know in the morning thanx again.
    Ok the desktop was also set to auto obtain but when I try to access it gives me an error code 678 on the desktop...
    well its a new day and I tried resetting the modem but I still get the same thing error 678 on my desktop and access on my laptop. Good thing my laptop works.... Also i noticed that my signal speed keeps getting low and will sometimes drop off???? Any help???
  • Anonymous Jan 20, 2009
    Icannot get my new mac to connect to my existing westell versalink 327w
  • 362 Answers
Try this, go to network connections, right click on your connection, click on properties, where it says this connection uses the following items, scroll down to internet protocol, highlight it then click on properties below it, make sure Obtain IP address automatically is checked. do this on both computers. Let me know if it works. lone99star
Posted on Jan 15, 2009
  • Jason Morris Jan 15, 2009
    Check the desktop, set it to automatic then try to connect both
    You should be able to connect with any and all of them, I think right now they are trying to share an IP address.Let me know what happens. Lone99star
I have Verizon DSL service on my Westell 327w. It
whenever the connection drops, is the DSL light blinking?
because, it is just normal for the E1 light to blink, but the DSL light should be solid at all times.
It can be a possible issue with the cable or the LAN card, but you still need to have your line checked by Verizon to make sure that it is not a modem or a network issue.
Feb 21, 2010 | Westell Wirespeed VersaLink...
Switching from a verizon 6100 dsl modem to a 327w versalink
make sure that your old setup not still on go to connect to from the start and right click on the connection and see the one that you are using is present
Nov 08, 2009 | Westell Wirespeed VersaLink...
I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
Jul 19, 2009 | Westell Wirespeed VersaLink...
Cannot get PPTP VPN to connect via Westell 327W (Verizon DSL)
Is the VPN server that you are trying to connect behind a firewall?
Jul 18, 2009 | Westell Wirespeed VersaLink...
Switching DSL Modems
Your dsl line stays the same. you're only changing your dsl equipment.
if you are not able to go online using the 327w, you might need to have it configured depending on the type of connection that you have. if you are using PPPoE (which means you enter a username and password on the modem to connect to verizon) you need your 327w configured for pppoe. but if you are using DHCP connection, any modem or routers should be plug and play.
Most verizon customers from the west coast uses DHCP while those on the east coast uses PPPoE.
You can call tech support to make sure which type of connection you are using.
Mar 29, 2009 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell 327W & Verizon DSL
I have centrytel DSL and westell Model 327W
Sep 09, 2008 | Westell Wirespeed VersaLink...
Verizon Westell 327w modem cannot connect to internet
hi. i work for verizon tv, internet and phone. and the tech was wrong. it is the unit it self how old is it?
Aug 07, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
166 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
