Question about Compaq Evo D300 PC Desktop
Lack of memory space
My computer man split the memory into local disk (C:) and local disk (F:). Now my C: is full and I need to shift to F:. How do I do it to create more space. I have compressed most of the files in C: but still I am running short of space... Please advise
  • hornbillexp
    hornbillexp May 11, 2010
    Please answer the above questions so that we can determine exact steps to free up some memory in your local disk C:/.
    I would not advice you to compress the said drive if your OS is installed on it. Compression will slowdown your computer. In case, if you are using xp/vista please run "file clean up" utility regularly, it is located under (Start>all programs>accessories>system tools>disk clean up.). It applies to both xp and vista (any version).
  • Jon May 11, 2010
    What operating system are you using? (i,e XP, Vista)
    How much space is on each drive?
    What is the total Drive Size?
    Do you want to keep both partitions/drives?
  • 114 Answers
You can adjust the size of the partitions with:
EASEUS Partition Manager (free)
http://www.partition-tool.com/download.htm
Posted on Jan 15, 2009
Could not initialize photoshop because scratch disks are full
Check to see if your system has enough memory and hard drive space. Photoshop should tell you how much memory and space you need. If this is a problem, you'll need to free up space. Photoshop may need to be uninstalled and reinstalled.
The scratch disks are areas of memory that hold your edits. If you don't have enough memory, you'll need to install more.
Nov 03, 2011 | Adobe Photoshop 7.0 for PC
I keep getting a note teling me that I have Low Disc Space on my Local Disc (D) - 4.87MB free of 119 GB. How do I free up this space. When using it's solution it just empies my Recycle Bin but this doesn't...
I would download and run the registry utility from iobit.com
It is freeware and works then run CHKDSK/F.
Within iobits programme are useful utilities that empty the temporary directories and can remove unwanted old files.
Hope that helps.
Mar 19, 2011 | Computers & Internet
Needs a space for local disk (D). what should i do?
- Empty recycle bin - Remove any temporary files - Remove any cached or page, swap files
Mar 17, 2011 | Computers & Internet
Low memory disk
If you have low memory disk, try to check your cpacity. To do this, click Start > then right click Computer then click Properties. You will check your RAM if it is 512MB, 1GB or 2GB. Then click Start then click My Computer. Then right click Local Disc C then click Properties. You will check the total memory space available. If the free space is very little already, try to remove unnecessary programs such as games... Restrart the pc and check if your space is still low...
Nov 25, 2010 | IBM ThinkPad R50e Notebook
We understand that your problem is: My desktop runs really loud and there is plenty of memory space available but it runs very slow. Its not consistent in the way it runs for example sometimes if I...
Format the Operating system and start fresh
Some useless programs or virus's may be slowing down your system
a reset will enable you to regain full speed of your pc again.
And don't forget even with loads of memory the CPU may be lacking to run most of today's programs all at once.
Sep 19, 2010 | Dell Dimension 4700 PC Desktop
How do i find out how much free space is left on my hard drive. the computer is moving slowly
click on "My Computer" right click on local disc "C" and click on properties. This will show you in graph form how much spave you have left. Slow downs on computers are more from a shortage of ram memory and lots of temp files clogging up the system.
Feb 11, 2010 | Dell Inspiron 710m Notebook
Cant download new Windows live messenger, not enough space!!!
Then you need to clear out more space to your c drive, you could try a program called **** cleaner (ccleaner)
http://www.filehippo.com/download_ccleaner/
if you haven't emptied your temporary files etc in a while, this program will most likely clear out enough space for you to install live messenger.
Nov 15, 2009 | Computers & Internet
Memory stick duo reads full but it is not really that full
There is a reserved amount of unused space that is required for files used to run it.
Think of it this way,A blank disk will show nothing.Add a one word document and write protect the disk,It will show the disk is full,Even though you know it only has one word written to it.
Please rate this a fixya
Jan 30, 2009 | Koutech Systems Koutech KW-2103MS Memory...
Brought computer an memory is full
Memory cannot be "full", Hard Disk space can be full. Is this what you are referring to? To free up more memory you can shut down some programs, you can also uninstall programs and delete files to free up more hard disk space. Or buy a new hard drive.
Dec 04, 2008 | HP Computers & Internet
Video Won't Save
The issue you have posted regarding that you are getting an error message that you cannot save the video because of not enough memory could be related to not enough drive space, I would appreciate if you could perform few steps below to isolate and fix the issue.
  1. Click on start point to My Computer and click on it.
  2. Once the My Compute page is displayed, right click on drive C and left click on properties.
3. Check if there is enough disk space available, if YES then follow the steps below or if NO then try to delete few waste or unused files to crate disk space, and try saving the video file that you were trying earlier.
  1. If you find that there is enough disk space then, try to save the file on the hard drive by selecting a different location, it could be that your are trying to save the file in a location which does not have enough memory or it could be right protected for example a CD.
In order to save the file on to a different location all you need to do is, Click on “File” and click on “Save As” option then in the box which pops up on your screen you need to look for a “Save In” option at the top and change it to “C:” or “Local Drive” and then click on “Save” at the bottom.
Should you require any further assistance regarding your computer related to this or any other issue in future please contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Compaq Evo D300 PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
