Question about Intel D845GRG Motherboard
Conecting front panel wiring to INTEL 845GRG MOTHERBOARD.
Need to know where the conection points are on the INTEL 845GRG Motherboard are
  • harleysnake Feb 28, 2009
    I have the same problem--motherboard manual download from intel site shows front panel connector block with 10 pins-9 used. The D845GRG board that I have has a 15 pin front panel block with 13 used? I'm afraid I might have already blown it! by hooking up the diagrams configuration. The board will not even start the pwr supply> Pwr supply starts if I jump green and black wires on power plug--fans run and standby led is on but no post or code beeps.
  • gooberyou Mar 27, 2009
    when I hook up the board, the power turns on but I only get fans and front panel lights.. nothing else.
  • 85 Answers
Normally a small area of 10 pins or 9 one is not used,you nedd the book or go to manufactuers website and download user manual,connect your wire to the board with out a diagram and you could damage the board
Posted on Jan 15, 2009
Mother board power switch
I don't know what you are asking for exactly, so I'll through out possibilities.
A) The Power On switch located inside the plastic Power On button assembly is a Momentary Contact Switch.
It is an ATX power on switch.
This is a generic example of a Power On switch that fits Many models,
http://www.amazon.com/Power-Motherboard-Cable-Switch-Button/dp/B00345WH4A/ref=pd_cp_e_2
B) The plastic front of the computer is a Front Panel.
The area of pins on the motherboard, that the cables (Wires) from the Front Panel go to, is the Front Panel header.
Intel Support > Intel D865GLC motherboard > Product Guide,
To find out if the problem is the Power On switch, or the Power Supply, perform the simple test using a jumper wire.
If you do not know how to perform this test, and wish to, post in a Comment.
Regards,
joecoolvette
Jul 09, 2011 | Intel D865GLCLK Motherboard
I want to know where the connection points are on the motherboard for the front mic and audio jacks. I have a epox ep-5pdaj motherboard. Will you send me a diagram please.
close to the back panel of the mainboard, below the back i/o connectors and 3.5mm audio jacks.
You need to remove the two jumpers from the pins, this is where you connect the front panel audio connector, if your case has each wire separate. then please look at this webpage http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm look at the part "For AC97 Front Panel Audio" PIN 1 should read MIC. If not, then scroll down, you are reading the wrong part of the page.
Aug 07, 2010 | EPoX EP-5PDAJ Motherboard
Stereo mix option not available
hi i am ashfaque from Bangladesh
Apr 14, 2009 | Intel D101GGC Motherboard
Wiring diagram
might be this one: ftp://download.intel.com/support/motherboards/desktop/se440bx2/72163201.pdf
Apr 01, 2009 | Intel Motherboard
My mother bord is d845glly. I am open my front, panel ,hrd wier .how to conect it again. please help me
If I understand correctly you are looking for the pin layout to reconnect your front panel cables. Here is the link for the manual for your motherboard which should show you everything you need to know about your board.
http://download.intel.com/support/motherboards/desktop/D845GLLY/ADLY_English.pdf
Mar 23, 2009 | Compaq (162857-001) Motherboard
No manual for conecting mother board
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4sp-mx%20se/e1676a.pdf
CLICK ON THIS LINK AND DOWNLOAD THE USER GUIDE IN PDF FORMAT WHICH U CAN READ ON A ADOBE READER
RAHUL
Feb 22, 2009 | ASUS P4SP-MX Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
My headphone"s mic is not working with rear and front panels and sound is scratchy also.
either the sound card is broken or you are just conecting it wrong. are you shure you have conected it in the red one?
Jan 06, 2009 | Intel Motherboard
Intel D845GRG Motherboard Logo
573 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
