Question about Pioneer CDJ-800 Turntable
Hey how come i cant use my loop features on my cdj800 with my serato?
You have to play it in absolute mode. It works! I looped last night at the club.
Posted on Jan 16, 2010
  • 515 Answers
It's the limitations of Serato. Because it's sampling in real-time, the signal cannot be manipulated by the CDJ800. Sorry, there is no way around this. Talk to Serato about this.
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Posted on Jan 17, 2009
How to connect serato dj,windows to pioneer ddj-sx
DOWNLOAD DDJ-SX DRIVERS AND RESTART YOUR COMPUTER
https://www.pioneerdj.com/en/support/software/ddj-sx/
Jun 15, 2014 | Rane Serato Scratch Live Computer DJ...
Serato does not recognise my technics turntable. The turntable is on and turning well but no response from serato. the arms in the serato do not move...help?
serato is a software to be used with an external soundcard it doesnt care what turntables you have. u have to a rane mixer or one that is serato capable in order to use it. then you have to go and link and sync your time codes
May 26, 2011 | Technics SL-1200M3D Turntable
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Ringing sound in background
sounds like there is a input to output loop of some kind. On some of my soundcards I was able to configure a virtual patchbay. Check around in the software for this and macke sure outputs are to outputs and ins to ins. Good luck.
Aug 28, 2009 | Rane Serato Scratch Live Computer DJ...
My comp cANT SEE serato scratch live
You have to hook up the SL1 Box or the 57SL mixer and then install the drivers. If you are not hooked up to either of these it will say 'Interface Disconnected' or 'Soundcard Not Found'.
Mar 24, 2009 | Rane Serato Scratch Live Computer DJ...
Error on the vinyl mode will let me cue but not play
More than likely you have a bad switch, although this is not something that you could service yourself. I would suggest taking it to a service center in your area. Make sure they are Pioneer authorized, and know what a CDJ800 unit is!
- OPTiC
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Jan 16, 2009 | Pioneer CDJ-800 Turntable
I have a Stanton T.80 and Vestax VMC-185XL mixer. I recently bought Rane Serato Scratch Live which requires the turntables to be grounded through the mixer...however, the turntable doesnt have a ground...
Hi gium
Sounds like we have reached that point where progressive crossover in technologies means that the usual cautions of earth continuity for the tone arm when using a phono preamp has gone the same way as phono preamps on home theatre.
Have you tried switching to the line level and set the mixer up for that level also. That may reduce any gain induced hum. However it sounds like an earth loop problem, where both decks will need to be earthed in the mixer. Check also that all the gear is running of the same power point. Different mains phases are sometimes available near each other, having any gear (power amps also) on a different phase will cause an earth loop problem.
Is the hum all the time independent of the volume levels, or change with levels adjustments and not at all when turned right down. Let me if changing to line levels helps. We can try some more things, like connecting a temp hookup wire earth to the RCA earth to mixer chassis. Cheers
regards
robotek
Oct 04, 2008 | Audio Players & Recorders
Setting up TTM 57SL, All I hear is control CD
This may seem too simple, but have you tried flipping through your channels on your mixer, or try connecting the wires differently.
Jul 31, 2008 | Rane Serato Scratch Live Computer DJ...
Using other sound cards with serato scratch live
Using pc onboard sound cards with serato scratch live
Jun 08, 2008 | Rane Serato Scratch Live Computer DJ...
Pioneer CDJ-800 Turntable Logo
249 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
