Question about Panasonic PT-47WX49 47" Rear Projection Television
Convergence images? Hi all, I bought this TV used last year and I'm wondering if I have it adjusted as well as it can be adjusted. After going though both the convergence steps I still see ghosting especially with an HD source. (HDV camera) Can anyone send me a few images of what a properly adjusted working set looks like? The blue tube on convergence 2 doesn't seem to be in focus but then the eye has a hard time with blue so... thanks, Steve Steveb48@aol.com
    Scholar:
  • 47 Answers
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Posted on Jun 15, 2007
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
I bought this new 4 years and I'm deeling with green and red issues mostly on the left side
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
Picture blured
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 30, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Double image, blue adjusted, red won't adjust
  • Screen looks 3D
Apr 19, 2009 | Philips 51PP9910 51" Rear Projection HDTV
Convergence Problem
  • Screen looks 3D
Mar 13, 2009 | Philips 60PP9202 60" Rear Projection...
The color in my TV seems to be going out.
  • Screen looks 3D
Feb 09, 2009 | Philips Magnavox 55P9271 55" Rear...
Projection lights
You need to take the Toshiba remote that came with the machine and go into a menu area that deals with convergence. Here's what the manual says:
This TV used 3 separate TV tubes, red, green, and blue. The R, G, and B images are pojected onto the screen wheree they converge to form a full-color picture. You can see a clear picture only when the three images converge correctly. Corvergence my drift over time, or if yo move the TV. I you can see clear images on your TV screen skip this procedure.
Make this adjustment only after the TV as been on for at least 30 minutes.
Press the TOUCH FOCUS (auto convergence) button on the front of the TV at the bottom.
The TV will enter into the convergence mode and adjust the converge automatically (that's what it says.)
TO ADJUST IT MANUALLY:
Press MENU, and the press < or > until the PICTURE menu appears.
Then press UP or DOWN to highlight CONVERGENCE.
Press < or > to display the Center Convergence menu
There's a lot more the book says, but, I can say from experience that you just go through the different sub areas of this menu and converge each color separately, and bingo, it's fixed.
Good luck.
Sep 06, 2008 | Toshiba 43H71 43" Rear Projection...
ALOT OF BLUE ON THE SCREEN!!
  • Screen looks 3D
Aug 20, 2008 | Philips 60PP9200D Television
Replacing convergence chips
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, etc.
Nov 15, 2007 | JVC AV-56WP30 56" Rear Projection...
Convergance Problem??
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Apr 26, 2007 | Hitachi 50GX20B 50" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
81 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
