Question about Frymaster Dean 2424G Deep Fryer
Heating problem with frymaster h14-2
This Frymaster h14-2 9804mz0058, will only heat until the temperature reaches about 70 degrees. Can you tell me what the problem might be or who can I call.
I prefere calling someone in Denmark.
Iben
    Problem Solver:
  • 5 Answers
Also check your High limit switch
Posted on Nov 10, 2014
    Problem Solver:
  • 8 Answers
Check if your Thermostat is bad or not calibrated...
Posted on Feb 28, 2009
I called IG Service in Denmark, who have their own technical experts, And they will now solve it.
I found them via the frymaster homepaige.
www.ig-gruppen.dk
Posted on Jan 15, 2009
Frymaster pump and motor
Hi there.
Filter paper may be clogged causing the pump motor to trip-off after the filtration of the second fryer, better scrape off any filtered debris on paper afrte filtering.
Also oil temperature must be at least 250F or above to lessen the load on pump motor as oil with low temperature is thicker than oil with high temperature.
Regards.
Apr 12, 2012 | Frymaster Dean Kitchen Appliances - Others
My fryer heat up to 285 then quit then try to light but want,
sounds like the high limit is doing what it is suppose to do. Check the actual temperature of grease with a perometer and see if it matches temp on computer if it is more than 10 degrees off or fluxuates irraticly change the temp probe. If it is dead on change the high limit.
Jun 25, 2011 | Frymaster Dean 2424G Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
I have a frymaster model mj35ssp cannot find where to light the pilot light at! Can someone please tell me
If you forward your e-mail address I will send you the Frymaster instructions w/ picture of where to light the pilot.
Rick
capt_rick1912@yahoo.com
Jul 21, 2009 | Frymaster Dean MJ35-SC-1 ''Standard'' Deep...
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Frymaster fryer keeps calling for help on electronic keyboard.
There should be some kind of spark sensor usually where the gas line plugs into the pot. There is one wire hooked to it take the sensor out and clean it good. Soot could be building up on it causing it to nolonger sense a flame.
Oct 25, 2006 | Frymaster Dean H22 Deep Fryer
Frymaster Dean 2424G Deep Fryer Logo
566 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
