Question about Sharp AL 1215 Black and White Copier
Sharp sf-7100 / status code
Machine always reliable.... Today whilst printing, machine stopped
and displayed status code H4......
Now what ?????????
Cheers, Robert..........
  • Claudio Neves
    Claudio Neves May 11, 2010
    Which status code it shows?
  • Claudio Neves
    What status code?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
H4 means the fuser can't heat up. The fuser lamp probably burned out. Sorry, nothing can be done without tools and new lamp
Posted on Feb 25, 2009
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
One number of photo copy machine drum cartridge wasinstalled. It worked once. Now machine is showing letter H and 4 flickering alternatively on the screen. Because of this none of the function of machine...
This code is almost always a false code. I would try clearing it by entering the following key sequence:
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" (Note that the exposure mode key is the far left key and that these 4 keys must be pressed within 4 seconds)
The display should have gone blank if these 4 keys were pressed properly.
Now enter 14 as if you were making 14 copies then press the Print Button.
This should clear the H4 code and the machine should operate normally.
If not and the H4 comes back then you have either a thermal fuse or heater lamp failure.
Good Luck
Nov 10, 2009 | Sharp AL 1631 Copier
Sharp copier SF-2025 displays an error code H4
H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
Nov 03, 2009 | Sharp SF 2020 Copier
Sharp Al-800 H4 Error Code
Press : CLEAR key - INTERRUPT key - O - INTERRUPT key.
The copy quantity display goes off and the machine is ready to receive input of test command number.Enter the two digit number to select the test commands.The test command number entered will be displayed in the copy quantity display.Press the PRINT switch.The operation corresponding to the entered test command number will be performed.For the test command 13 and 14 since test commands 13,14 are used to clear the contents of the diagnostic status (U1,H3,H4)stored in the LSI,the diagnostic mode will be automatically canceled after completion of the test commands.
Jul 30, 2009 | Toshiba e-Studio120 Copier
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
I have a Sharp SF-7100 and it shows a H3. what does that mean ?
fuser code, try typing in clear, repeat, zero, pause (Within 5 seconds) machine should go blank, type in 14, then start button. Machine should reset. If the code comes back it is a lamp or thermister and you probably cannot get those anymore. that machine is over 20 years old
Mar 13, 2009 | Sharp Office Equipment & Supplies
Showing h4
If your machine is AR-5316,
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Mar 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Our Sharp AL-1645cs copier shows an H4 command in the display. What does this refer to ? thank you for showing us how to fix this problem. Thanks
The problem on your machine is on the fusing unit, the temperature in the fusing unit is low to start the machine. To cancel the trouble status follow these steps:
Press CONTINOUSLY the following:
STEP1. Press CLEAR key then EXPOSURE key then CLEAR key then EXPOSURE key
STEP2. Then you are inside the simulation if the display turns OFF if not do again step 1 until the display turns off.
STEP3.press 14 then press print button
The machine will now cancel the trouble status and ready to used. If not cancelled and again H4 exist it means that there is a part inside the fusing unit that is busted like the thermostat. With this you should now contact your authorized serviceman to check your machine .
Feb 23, 2009 | Sharp Office Equipment & Supplies
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
Sharp AL 1215 Black and White Copier Logo
254 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
