Question about Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range
Clock cuts out stoping oven
I try to set the time on my clock it then flashes and the oven cuts out if i hold the button in the error c11 comes up.
How do you set the clock on the Electrolux cooker?
You didn't specified the model of the oven so it is possible to set in a different way. There are several kinds of timer (with tree, four, five and six buttons) depending on the model of the oven. Here is explained how to set clock on the most common oven timer with three buttons.
First of all, the oven only operates when the time has been set.
When the appliance has been connected to the electrical supply or when there has been a power cut, the function indicator Time flashes automatically.
1. To change the time that has already repeatedly, until the function indicator Time flashes.
2. Set the current time using the "+" or "-" button.
After approx. 5 seconds, the flashing stops and the clock displays the time of day set. The appliance is now ready to use.
Dado
Mar 18, 2015 | Electrolux Ovens
How to set clock please
They're all different.
But usually there's a button that says "CLOCK".
Press it in and hold it until the display starts flashing just the hours. Set the hours, then maybe press the clock button again and maybe the minutes will be flashing.
Or maybe on your oven, once you get the time flashing , you can set both minutes and hours with the number buttons.
Like I said, different manufacturers have different instructions.
Mar 16, 2015 | Microwave Ovens
Forno sy36x oven.. following powercut, timer wont set, therefore oven wont come on. digits constantly flashing
after a power cut, the clock display will-automatically reset to 0:00 and begin to blink.
starting buttons left to rigth Press the
2nd and 3rd buttons simultaneously, release,
and then set the exact time (within 4 seconds) using
the +buttons.
advances the hours.
The button
- decreases the hours.
The time can also be changed in a second ways
1.Repeat all of the steps above.
2.Press the 4th
button, release, and then use the +and -
buttons to update the time.
Sep 23, 2014 | Ovens
EWF 10680 a code comes c11 what does this mean
C11 isnt an error code. This comes up when you go into test cycle.
To get the error code out you need to turn the dial to any setting apart from the first on the right.
Then press and hold the start button and the button to the left of it and after a few seconds an error code will come up E??
What is that code?
Oct 14, 2012 | Electrolux Washing Machines
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
Their was apower cut now the clock and fan oven wont work. but power to the grill and gas is still functioning . rangemaster 110
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
Apr 15, 2010 | Rangemaster 110 (Gas) Kitchen Range
How do you set the clock on an electrolux premier built in single oven after a power cut as time is flashing and auto is showing and only four buttons and no instruction manual.
hold down the first two buttons on the far left then turn the little diel button,this will set the time.also you can set the timer useing one button hope this helps roscargou.
Feb 15, 2010 | Electrolux Ovens
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Lofra MXGC96AMF/CV Dual Fuel (Electric and Gas) Kitchen Range Logo
37 people viewed this question
Top Lofra Kitchen Ranges Experts
paulcarew
Iron
Iron
Tom Chichester
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
