I am not able to take printouts in html.i want the printout with scroll and title bar.pls provide me with the settings in html
If i get you right, you want to print the whole browser's windows (with title, menu, buttons etc).
In this case
1) check that the browser's your active window
2) go to the page and the place in that page that you want to print.
2) take the screenshot of the active window by pressing Alt+Print Screen
3) ru PaintBrush (a graphical editor) by pressing Win+R and typing 'mspaint' (without quotes) and pressing Enter in the 'Run program' window that will appear
4) when the editor starts, press Ctrl+V and answer Yes if it asks you whether you want to enlarge image
5) now you should see the snapshot of your browser's window inside the editor. Press Ctrl+P and click 'Print' when in 'print' dialog appears
Posted on Jan 15, 2009
For some reason we have not received a diagnotic printout since march 2015. we were wondering why.
I wonder to but no way I can help you. Contact to one who promised you to provide your diagnostiic printout. Fixya has nothig to do with your personal business
Jun 02, 2015 | Cameras
Hello, i attached ink tank to my epson r230 printer from last 2 yrs but yesterday i fill tank & then take printouts but in printout having more red colour. pls give me solution.
Sounds like your CISS is the problem. I suggest you get Refillable Cartridges that automatically reset themselves. I have them for a WF840 and they work flawlessly.
Feb 28, 2014 | Epson STYLUS R230 InkJet Photo Printer
How to print out activity report
What model do you have? Printers do not genrally printout activity just copy counts. If you have a multipass, or L series Fax, the activity report is accessed thru the menu buyyon. Just scroll until you get to reports press the set button and tou should be adle to scroll to the report you want.
Let me know
Jan 10, 2011 | Canon Office Equipment & Supplies
Fax printout (successful or not) required
Press
function
74
set
12
set
press 2 for always or 3 for incomplete only
press set
press stop
Jun 05, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Not getting printout from pdf folders
Get an updated driver from usa.canon.com
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2279&modelid=6290
In printer properties, device settings, press get device status. The driver should auto-configure with your correct finisher details.
Use the print driver's layout or finishing tab to set two sided print.
Jan 31, 2009 | Canon imageRUNNER 7200 Copier
Printout problem
Hi Jpex,
If all the other printouts are fine then the problem is more than likely with the programme that the file is downloaded to.
Save the document and the click on edit and change the contrast settings to make the print darker
Regards
Gavin.
Oct 06, 2008 | Brother IntelliFax-2820 Laser Fax
Lexmark x5150 all-in-one inkjet printer. trying to get the fax to work. i have dsl.
You may have to experiment to get the fax to work on DSL. Try these suggestions: press MENU, then scroll to:PRINT REPORTS. Scroll to HELP LIST and press SET BUTTON. Press START button to print HELP LIST. On the HELP LIST printout, locate the FAX MENU. Using a cell phone, call your fax and see if the fax answers. If not, try changing the following settings (change one setting, then call the fax with the cell and see if it answers, Make sure you set each changed setting back to what it was, until you find the right one.) try changing: RING DELAY, F/T RING TIME, EASY RECEIVE, OVERSEAS MODE. Also on the HELP LIST, find the INITIAL SETUP MENU. Select RECEIVE MODE, and try each option, again calling the fax with your cell until it answers.After you get the fax to answer calls from your cell, try sending and receiving with another fax, or use Brothers AUTOMATIC FAX-BACK SYSTEM, which will automatically send your fax a test printout when you call it. Just call 1-800-521-2846 from your fax machine, IT MAY BE ALREADY PROGRAMMED INTO YOUR MACHINES AUTO DIAL LIST, AUTO DIAL NUMBER 001..
Aug 16, 2008 | Lexmark Office Equipment & Supplies
Want to get a fax confirmation
to get a printout of all faxes press function then 6 then use arrows to scroll through the menu use set or start button to confirm
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Ink blobs on edges of printouts
Dear sir,
I figured out this problem it may cause; The problem behaves strangely why only on the right section the printout is not fused. The common section I first check is the high voltage circuit causing no static properties the powder shall be fused with the drum's developer. Now, it is clear also that the cause is within the drum. Pls check drum's life by printing the machine diagnostic details to check all moving and consumables counters. Clean the drum by rotating the developer roller. Well see if there's a irregularity of powder distribution. Have a nice day.
Feb 06, 2008 | Office Equipment & Supplies
Fax history
Depending on your model, You need to press the MENU button, or check if there is a REPORTS button. For either case, scroll through the display until you come to the PRINT REPORTS mode. It may be worded differently on your machine, but what you are looking for is the FAX ACTIVITY report. You can also get printouts of TRANSMISSON OR RECEIVE ACTIVITY, and also CALLER ID, iIf you encounter a command called PROTOCAL DUMP, this also is a printout of fax activity.. Whether your activity report goes back to july 2007 is unknown. Normally an activity report shows a certain number of activities per printout, say the last 50 fax operations. It is not based on a certain timefrane.
Jan 09, 2008 | HP 920 Plain Paper Fax
41 people viewed this question
k24674
