Question about JVC HD-61G787 61" Television
Screen their a hold in the screen how much will it cost to replace the screen for a 61inch
    Scholar:
  • 87 Answers
The part # is 61SC-006A-M2 with a cost of around $439.99 with free shipping.This will include all 3 screens. 1-866-925-PART (7278)
Posted on Jan 15, 2009
My Samsung DLP is each day getting more and more white spots. Please help me
The dlp chip is bad and will need replacement to fix the white dot issue.
Dec 13, 2012 | Televison & Video
Scratched tv screen
there is no way to get cleared of the scratches done with sharp things....
it should be replaced fully which would cost much of the tv amount itself
May 14, 2008 | JVC AV-48P575 48" Rear Projection...
NUMBER 3 FAN WARNING ON SCREEN THEN TV SHUTS OFF SAMSUNG 61INCH DLP
It could be that the bulb/fan unit has come unseated inside the TV. If you want to attempt this repair yourself this is a good reference:
http://forums.cnet.com/7723-13973_102-321561.html
You may need a new lamp unit but the same instructions would also allow you to install a new one.
Jun 27, 2011 | Televison & Video
HOW MUCH IS THE LIGHT ENGINE FOR A 61INCH PROJECTION SCREEN
They range from $200dls - $350dls depends where you get it from here is a example
http://cgi.ebay.com/PANASONIC-PT-52LCX66-LIGHT-ENGINE-DMD-ASSY-/120628821223
Oct 05, 2010 | Panasonic PT-52LCX66 Projection Television
I have a 61inch husq. the belt will not stay tight
First make sure you have the correct size belt, compare with old one. If they are the same then you have the belt routed the wrong way, you are most likely missing the tension pulley in your current routing of the belt. Usually there is a diagram either on the deck of the machine or in the owners manual.
Sep 24, 2009 | Garden
My samsung dlp 61inch dont have any power on it.Is there an automatic shut off switch in the back panel? This had happen after I replaced my colorwheel.I dont have a manual for this tv.
did you replace the color wheel yourself? if so, it's a good possibility that something came unplugged or wasn't plugged back in correctly. retrace your steps.
Jul 31, 2009 | Samsung HLP6163W 61" Rear Projection...
Seeing doubles
there is an adjustment called convergence.the convergence setup generates a crosshatch.you need to adjust the red deflection.this is a common thing when the t.v gets moved.the crosshatch or convergence button is mostly on the front control panel.consult the manual for where it is.
May 22, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Scratched tv screen
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Mar 18, 2006 | RCA P61927 61" Rear Projection Television
JVC HD-61G787 61" Television Logo
73 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
