Question about JVC TH-M505 System
Jvc dvd TH-C6 says locked and dvd wont eject
For
  • 1 more comment
  • Anonymous Jan 16, 2009
    System states " reading" "no disc" locked" it will not open.
  • stigymech Feb 21, 2009
    displais says "LOCKED" and can't open or eject any tray, no disk in system.
  • Anonymous Mar 18, 2009
    Mine does exactly the same thing
While the system is off
Press and hold the stop button and disc one open tray button at same time
It will say unlocked and then power up and you are good to go
Hope this helps i just unlocked mine got info from jvc user manual on website this link is the pdf
http://resources.jvc.com/Resources/00/00/95/LVT1147-001C.pdf
Posted on Mar 18, 2009
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
When I want to open the dvd-player it says: LOCKED
There will be a tiny hole in the front of the drawer where you put DVDs in.  This is the override.  With your system switched on, poke a paperclip in there and the drawer should eject.
Hope that helped.
Mar 13, 2010 | JVC TH-C6 System
JVC TH-G31 dvd player says locked and it won't eject. Help, please!
while unit is off hold the stop button until it says unlocked
Jan 26, 2010 | JVC TH-G30 Theater System
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
Jvc th-c6 subwoofer won't turn on
Check the little prongs inside of the cord, they are very fragile and if they get pushed in wrong, bent and broken off - you would never see one on the floor. These should all be straight and be able to make contact. Hope this helps!
Feb 08, 2009 | JVC TH-C6 System
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
Locked jvc dvd cinema system th-s55
With the machine turned off (not off at the mains mind you) press and hold the stop button and then while still holding the stop button, press the eject button. Turn it back on and hey presto! This method will unlock it when its locked and vice versa. p.s its in the manual
Nov 05, 2008 | JVC DR-M1 DVD Recorder
Jvc th m505
instruction book says: on the center unit ONLY WHILE UNIT IS OFF there is a button with a square under it (on top of unit) press & hold also press & hold disc 1 eject button (arrow pointing up). The system turns on & "UNLOCK" appears on the display window.
May 27, 2008 | JVC TH-M505 System
DVD Player wont eject, Locked
disassemble the unit and eject manually
May 09, 2008 | JVC TH-C3 System
How do i unlock my jvc th-m505 dvd digital theater system?
Hold the STOP button and push the EJECT button.
May 15, 2007 | JVC TH-M505 System
JVC TH-M505 System Logo
550 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
