Question about Microsoft Xbox 360 Console
Xbox 360 2 red lights
Hi basicly i recently fixed my xbox 360 it had 3 rrod and i x clamp fixed it afterwards when you go to overheat it with the fan unplugged instead of waiting 10 - 15 minutes after 2 it two red lighted and now when i turn it on it boots then after two minutes it 2 red lights again i am completely stuck i have tried everything i could possibly think of and i am puzzled if anybody could help that would be much appreciated
    Scholar:
  • 33 Answers
I suggest you to try DIY Guide that wil explain solving the 2 red lights along with some other common problems of Xbox like Disc Read Error, No Video Problem and most famous RROD. Even a novice can solve the problem with the help of step by step process given at the guide. I think it's worth trying. If you try this method, you won't have to wait for 3-4 weeks and you can enjoy your gaming experience within 2 hours, once you try this guide.
Posted on Mar 05, 2009
    Sergeant:
    Champion:
  • 378 Answers
Its possible you could of overheated the solder under the GPU chip and you may need to have the chip replaced and reflowed. We have had success in reflowing the chip. We are listed on this site for repairs. If interested email us for free estimate.
xbox360fixer@verizon.net
Thanks
Posted on Jan 15, 2009
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 repair 3 red lights
The 3 red lights issue is known as the red ring of death(or RROD)
This is caused by the x clamps used to hold down the processor.
The x clamps cause to much pressure which causes the xbox 360 to think it is over heating. Microsoft has issues a extended warranty for RROD issue. You can reach Microsoft by calling 1800 my xbox. The link below is to a Youtube video walk through on how to resolve the issue.
http://www.youtube.com/watch?v=fuIl0kGf7dM
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console - Black
I have two red light on my xbox when u turn it on and nothing works?? the lights are the two left lights and the console turns on for 15 seconds then the fans shut off and red light blink?? any ideas any...
Here it is. The two red lights is a "general hardware failure" but I find most of the time it is the CPU's fault. This happens when the CPU is not kept cool enough so the Xbox shuts down to prevent overheating. Basically it's the same deal as the RROD. To fix it you should do this:
A) Send it to Microsoft for repairs if you're still covered.
B) Send it to a trusted Xbox Repair center. I currently run one called DRAGONF1R3 REPAIRS.
C) Go online and purchase a RROD X-Clamp fix kit. This should come with instructions on how to fix your X-box 360 by yourself and the Hardware you will need.
These are your three best options. If you need more information on my Repair service feel free to e-mail me. (my e-mail is in my description)
I hope I helped you out.
Jan 24, 2010 | Microsoft Xbox 360 Console
3 red lights
you have the red rings of death which means that your xbox 360 is over heating or needs the rrod repair there are parts you can buy on ebay and guides to fix this problem if your confident enough to void warrenty cause you have to take the xbox apart and remove and replace the x-clamps that are on the bottom of the motherboard and it is a pain cause i ve done that repair on mine or you can find a repairer in your area to repair it for you
Nov 10, 2009 | Microsoft Xbox 360 Console
3 red lights flas when power is turned on
You have what is known as the xbox Red Ring Of Death aka... RROD.
If you are the original purchaser - Microsoft is fixing them for free (but you will be without your XBox for about 6 weeks.)
Basically - the RROD is from not enough thermal compound between the heatsink and processor. It overheats and goes into 3 light error mode.
There are sites that will fix (for a fee) and even videos on YouTube that describe how to fix it yourself if you are inclined to do that.
It entails opening up (and voiding your warranty) the 360. There are so many hidden screws and latches - it is imperative to find a video or step-by step instruction on opening it properly.
I would suggest sending in to Microsoft so your warranty is not compromised.
Otherwise - see THIS SITE for step by step instructions on opening, cleaning, and replacing the thermal compound.
Other places can be found simply by googling "RROD FIX" or try YouTube and look at some "RROD FIX" videos.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 25, 2009 | Microsoft Xbox 360 Console
How can i get the red light to go out
This is a quick vid on fixing the 3 RLod in the Xbox 360. There are NO swaps in this video...it is the same xbox from start to finish. I've done about 20 of these the same way. BTW...everyone is asking me about the song.. its called Planet Me by Cage9 a band you guys should check out!XBOX 360 Repair 3 Red Lights of Death Rrod X-Clamp Fix
Jun 13, 2009 | Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
Ive tried the 3 light fix for the xbox 360 it keep shuting down
Make sure you have all the clamps on the chips tight. If one pops loose it will cause this.
Jan 13, 2009 | Microsoft Xbox 360 Console
My xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Mar 21, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
114 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
