I WANT TO UNINSTALL DEEPFREEZE
WHEN I INSTALL THIS SOFTWARE ASKING PASSWORD THEN ADD MY PASSWORD BUT MY SAVED FILES ARE NOT SHOW AFTER THE RESTART SO PLEASE HELP ME TO REMOVE THIS SOFTWARE FROM MY SYSTEM
  • 3 Answers
I'm not really sure about the "DeepFreeze" software - but I do know that after months of me trying to remove a failed uninstall of Anonymiser software, that the only thing that could get rid of it for good was a program I downloaded from uninstaller.weebly.com
It really did work. The software makers also have a good support system, and they provide a way to email them the program details and they will do their best to investigate as part of the service provided with the software.
Hope it helps you - like it did for me!
Posted on Jan 24, 2009
How i can uninstall deep freezer
Please use the Deepfreeze software to uninstall the Deepfreeze from the Computer. I mean use the Deepfreeze software "Deepfreeze.exe" file on the computer which you have already installed the Deepfreeze to uninstall it!
Mar 27, 2011 | Computers & Internet
How to uninstall deep freeze 6 and where to find the files to delete
hi
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
Note: I tested this method on Windows XP only, on another windows version maybe this method does not work.
Jun 27, 2010 | Dell Computers & Internet
How to delete deepfreeze
Hi. I think if that deepfreeze workstation program has password then you should know it and enter that password by pressing and holding CTRL+ALT+SHIFT then press F6 then enter the password. After that you must change the state to THAWED state then restart your computer. Your deepfreeze icon on the lower left should have an X marked now that is blinking, it means that your deepfreeze is already disabled, now you can uninstall it by using the same installer that you use to install your deepfreeze workstation. If you dont know the password you should have the main installer for deepfreeze 6 that creates a workstation installer and you can use that main installer to generate a password for you to login your deepfreeze workstation. Hope This Helps
Jun 04, 2010 | Computers & Internet
How to remove deep freeze from computer srinu K
You have to go to your computers boot menu and boot into deep freeze menu and you must have the password. If you do not have that password you will need to completely re-install your operating system. You can also access the deep freeze menu from within windows but again you have to have the password
Mar 17, 2010 | Computers & Internet
I cant remove the deep freeze software standred 6
read this :
http://www.faronics.com/faq/default.asp#7
1-This software (protection) is effective, it is
impossible to ignore, unless you remember
password entered at the first reboot after
installation password that allows you to unfreeze
the position, necessary step prior to
uninstallation. To access the password window
Password combine the ALT + CTRL + SHIFT + F6, then
choose "boot Thawed" and restart.
2-for Windows 2000 or XP
Go to Start-> Control Panel-> Tools
Administration-> Services
click on right click then Properties DFServEx
in the general tab in Startup type: select
Option deactivated
then reboot and all will be resolved
3-http: / / www.faronics.com/
4-for disabled deepfreez is simple
pressed the button shift + double click on deepfreeze
nearby clock. enter the code if you enter the / if you did
not click OK.ENSUITE CLICK ON BUTTON LE3EME
ENSUISTE OK and restart THE PC
after the boot up you found approximately one thinks red
deepfreeze ok
releancer installing deepfreeze and its SETUP
you found approximately UNANSTALL OK UNTIL THE END
AFTER rebooting TT WILL BE AS BEFORE
5-download the recent version of deep freeze and
installation and during installation it asks you
uninstall the previous version and continues to validate
jusqau he asks you to install the new version
cancel
Sep 09, 2009 | Computers & Internet
Deep freeze feronics V6 satandart
Double click to the taskbar Deep Freeze icon while pressing the Shift key, If it is password protected, give the password. Select Boot Thawed from Boot Control and restart your computer. Now open your Deep Freeze installation file (by which you have installed it). Now you will have the option to uninstall it.
Enjoy...
Apr 22, 2009 | Computers & Internet
Problem of uninstalltion of deepfreeze software
use spybot s& d advance to remove this from your system
Feb 07, 2009 | Computers & Internet
Deepfreeze from my computer is not working properly
try uninstalling deepfreeze, it might solve your problem.. to uninstall deepfreeze, you must run the Installer file of deepfreeze..
Feb 03, 2009 | Ahead Software Nero 5.5 (NERO5.5) for PC
How to uninstall deep freeze from your pc?
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
  3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
  4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  2. Run the installation file (DF5Std.exe or DF6Std.exe).
  3. Select the option to "Uninstall"
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Apr 08, 2008 | Computers & Internet
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
