Question about Zenith Z50PX2D 50 in. Plasma HDTV
Zenith plasma tv picture blinks on and off, sound ok
I had two black lines going up and down. I fixed those with new solder. Had green dots and and picture blinking or flashing black with sound still coming through good. I was told to replace the Y-sustain board. I replaced it with a new one and it only fixed the green dots. What is causing the picture to cut in and out?
  • 7 more comments
  • wolfe77_7 Jan 15, 2009
    Model #P42W46X. How do you test?
    The picture cuts in and out on all inputs. Can I just replace one piece? The cost of the main board is alot. How do i test? I have a multimeter.
    No magnetic field.
    no magnetic things around.
    no magnetic fields around
    I already paid!
  • wolfe77_7 Jan 19, 2009
    I also replace the main board, but the picture is still cutting in and out. I figured out that it only cuts in and out under a load.
    I replaced the Y-sustain board, the main board, and paid a repair guy to come out. he wanted an arm and a leg. he said it looks like it could be the formatting board. what do you think? How do you rate people?
    I just got a sulotion saying to replace my main board! I just replaced it!
  • 142 Answers
Make sure the connection from the service provieder is clear and working. If i were you and were having all of these problems, i would call in a professional to diagnose the problem in person, because this is somewhat difficult for us to diagnose in person.
Posted on Jan 19, 2009
    Scholar:
  • 87 Answers
Let`s see if we can get to the bottom of this.Unlike the other responses you have recived we are going to bypass all the magnetic fields,and other ideas that have nothing to do with how a plasma TV works.This unit is actually a LG Tv.I work on these all day long so let`s see if I can help you.What was the original problem that this unit was having ? When you say the picture is blinking off and on,is the uniit powering off and coming back on or is there actually a picture that blinks off and on?How rapid is the picture bliknking?
  • Albert Vasquez
    Albert Vasquez Jan 20, 2009
    On the back of the panel on the left side up top you should see a white sticker as listed VA:60/VS:185.These are your operating voltages for your Y-sus And Z-sus.The connectors @ the top of thr Y-SUS board will have these labled VS and VA.I see you have a voltmeter.On the same connector you will see GND.This is ground.Set your meter to DC and check the voltages.You can stick your meter leads right into the connector where the wires go in.The black goes to GND and the red goes to VS or VA. Turn the TV on and check to see if these voltages are close to what the sticker indicates they should be?Also check to see if they are changing as the picture flickers.Let me know what you find and we can go from there.
  • 8,197 Answers
Your main doad went out. You need to replace it.
    Genius:
  • 2,920 Answers
It could be the tuner board going bad..
Posted on Jan 15, 2009
  • Ronnie Houston Jan 19, 2009
    do yourself a favor.....call a repair man out..people are telling you the same things youve already done and not bringing you a solution and it will save you time and money in the long run
    Genius:
  • 1,665 Answers
Hi!
Check also for any cold solders or loose connections or faulty cable.
  • 837 Answers
If you cannot locate "free" on-line info this link is a good source to "buy" what you need
    Sergeant:
  • 378 Answers
Check wether u have some high sound speakers or some kind of magnetic field close to your tv.it should be atleast 2 feets away and then after taking away such disturbance causing things,u will need to shut off and power on ur tv multiple times everytime keeping your tv on atleast for 2 minutes until those cutouts go completely from screen.
rate the solution accordingly.
    President:
  • 2,110 Answers
Make sure that there is no Magnetic feild around the plasma.
  • Zenith Master
  • 19,396 Answers
Test cables and lower buffer, more likely the problem is a defective video processor IC on main board, that is not serviceable, and board miust be replaced.
Test also inputs, check that it is not just a bad signal board or a input/cable problem.
  • Ginko
    Ginko Jan 20, 2009
    You need to test the VSC board (video scan converter), and the digital board.
    Testing this boards is not easy operation, and you need to follow indications on service manual.
    Service manual can be purchased from Zenith, or from sellers like Vance Baldwin or partstore.
    To give you an idea, here is service manual for a similar model.
My zenith plasma tv popped real loudlike a car backfiring and then the tv picture went black. power on green light wil turn on but it automatically cuts itself back off to the red light
Something blew.... like overheated and just basically blew up..... Was it on for a long time? You may to check your warranty to get it fixed or a new one.... or you may have to just buy a new one....
Jan 09, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Tv black with red green yellow dots but when warms up it alright
Try backstepping the set resolution on your TV to see if that cures it.
Please rate my help++++Thanks for using FIXYA
Mar 06, 2010 | Gateway GTW-P42M303 42 in. Plasma...
There's an over current fault in the power supply or the Y-sustain convergence board. The loud pop was either a capacitor or pico-fuse breaking from excessive current overload. Sounds like 2 or 3 mosfets have shorted at the gate ends. Plasma TV's always have this problem because they generate too much heat and the components cant take the load conditions. Make your next TV an LCD...
To fix this problem have your local repair shop do it for you.....
any questions please ask.....
Jan 20, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P42W46X - no picture
if the lines covered the entiire screen, fist I would check to see if the TV's menu can be seen. If not then check the buffer boards. Next I would check the logic board
Jan 09, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Black lines on sony plasma tv
go here, it will work.  follow closely and read entirely!  it worked for me on a gateway plasma!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Oct 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Plasma tv repair question
Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
Started as 1 then 4 over 4 months
Aug 10, 2008 | Televison & Video
Junk TV & Poor service
zenith agreed today to replace mine.
Mar 12, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Green light blinking- no picture
This just happened to my Z50 yesterday...10 days after it came back from the repair shop! The first repair was for the "popping" problem where the tv makes a loud pop and the screen goes black. This took 6 weeks to get fixed. For this new problem the repair center is getting hold of LG to find out what to do. I am also calling them because I see this is a major problem that people have been experiencing out of warranty. The first customer service rep told me I was out of luck but I am not accepting that answer. Good luck, we'll both need it.
Feb 05, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Screen full of moving colored lines
I would suspect bad solder connections allowing a ground to "float" It is a common problem with the model P42W24BX which I believe uses similar circuitry as your model. An experienced repair shop should be able to get you fixed up.
Dec 18, 2006 | Zenith P42W46X 42 in. Plasma EDTV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
49 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
