Question about HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook
Battery Discharging when pugged off
I have ho dv 6000 laptop and the battery starts to discharge whenever it is switched off completely from the AC supply. When the laptop is completely off the battery starts to discharge itself.
    Problem Solver:
  • 82 Answers
Pls check with the local service center for battery or go for a new battery........................Sameeraryan
Posted on Jan 15, 2009
Does the battery have to work for the lap top to work when pluged in on the Presario R3000?
Check your AC adapter if still work. Battery don't have to work when is on AC.
Dec 26, 2011 | Compaq Computers & Internet
Tip
AC Adapter issues Q & A.
<p><b>Laptop switching to battery while connected to AC adapter</b><br /> <p><b>Q.</b> While turned on, the laptop will switch to battery power even if connected with the AC adaptor (sometimes during boot-up, or after a while) until the battery drains out, he then goes to hibernation (the battery light is off). If no battery in the laptop, it will shut down, and the AC light will blink very fast. The battery (li-ion) will only charge up to 10%, where it then jumps right up to 100%, and will discharge from 100% to 90% then jump to 0%, go to hibernation, and fails to complete the process, shutting down. The adaptor makes a small "camera flash charging" sound, stabilizing at 19v. When charging, it repeatedly makes the "charging sound" Faulty AC adaptor? Or Faulty battery? Or Both?<br /> <p><b>A. </b>First problem: The laptop switches to battery power even with connected AC adapter. Most likely you have a faulty power jack. It's either broken or loose. It's a known issue with laptops and you can fix it by replacing/resoldering the power jack or relocating it outside laptop case.<br /> <p>It also could be a problem with the power cord. Find a multimeter and check the AC adapter. See if the power cuts off when you jiggle the power cord. If it does, replace the adapter.<br /> <p>Second problem: The battery will discharge from 100% to 90% and then jump to 0%. It sounds like a bad battery.<br /> <p><b>Battery charging light is on even when power adapter is unplugged and laptop is stitched off</b><br /> <p><b>Q.</b>The yellow light for battery charging does not go even after switching the laptop off and power jack is disconnected. Battery does not charge at all with power source connected. <br /> <p><b>A.</b> First of all, try reconnection the battery if you haven't done it already.<br />The battery plugs directly into the connector attached to the motherboard. If the battery charging light stay on even when the power adapter is unplugged and the laptop is switched off, it's either bad battery or something is wrong with the motherboard. The only way to find the culprit is testing the laptop with another known good battery.<br /> <p>Also, you can try this. Remove the battery and plug in the power adapter. If the battery charging LED lights up even when the battery is removed, most likely you have a problem with the motherboard.<br /> <p><b>Battery charges only when the laptop is off</b><br /> <p><b>Q.</b> Bought a Laptop without AC Adapter. I noticed it would charge the battery OK when the laptop was off but once in windows it would not charge the battery.<br /> <p><b>A.</b> This is very important to choose the right AC adapter for your laptop. The output voltage MUST be exactly the same. If your laptop requires 18.5V you must use 18.5V adapter. The amperage should be the same or higher. If the laptop requires 4.74A adapter, you'll have to find an adapter which provides 4.74A or MORE. <br /> <p><b>While using AC adapter alone or battery alone, laptop works. While using them together, I am getting a problem.</b><br /> <p><b>Q.</b> While using AC adapter alone or battery alone, laptop works. However while using them together, laptop LED lights blinks and the power meter for battery drops down immediately to 0% critical level, whereas the battery LED indicator says it's full. I tried to unplug the AC adaptor while it went down to 0%, then the power meter for the battery came back to normal 85%.<br /> <p><b>A.</b> There could be a few different reasons why it happens:<br />1. It might be an issue with the BIOS. Make sure the laptop has the latest version of BIOS installed, update it if needed.<br />2. It might be a software related issue. If you have some kind of power management utility installed try uninstalling it and use Windows power management utility instead. Also I would try reinstalling the operating system if upgrading the BIOS or removing the power management utility does not help.<br />3. If you still experience the same problem even after upgrading the BIOS and reinstalling Windows, most likely you have a problem with the motherboard. Apparently the charging circuit is not working properly. I assume it's not a problem with the battery. You'll have to check the motherboard in this case. <br /> <p><b>Problem with my battery. 100% to about 40% the battery discharging normally then suddenly from 40% it drop directly to 2%.</b><br /> <p><b>Q.</b> When I use only on battery, from 100% to about 40% the battery discharging normally (last about 1 hour) then suddenly from 40% it drop directly to 2%.<br />When I plug the AC cord, it won't directly charge (the charge LED is still not on). After 10 to 20 minutes it then starts to charge the battery (the indicator say that it can be charged to 100%).<br />If I turn-off the laptop and then charge the battery, it won't also directly charge but the delay is much shorter (maybe just about 1-2 minutes).<br />Is this the sign of a bad battery (when hot it can't be charged?) or maybe a bad AC adapter (not enough power to charge the battery when the laptop is turned on?)<br />Note that this symptom is always repeating when I use the laptop.<br /> <p><b>A.</b> From the first part of your complaint description I can see that you have a bad battery. The percentage might vary, but the process of discharging is the same - the battery discharges fine until some point and then the remaining charge suddenly drops to the minimum. You'll have to replace the battery.<br />I'm not sure about the second part. Probably it's a battery related problem too. Just in case check if there is a newer version of BIOS available for your laptop. If you find one, upgrade the BIOS. <br /> <p><b>The battery is 100% charged but it will die within a few minutes as soon as the laptop is unplugged.</b><br /> <p><b>Q.</b> When I unplug the power it will run off the battery, the battery icon says it is 100% charged and I have 2+ hrs remaining, but within a few minutes I get the "critical battery level" message and it will die. When I plug it back into AC power the battery charge light comes on (and will remain on for over a hour), but I will have the same problem with it dying as soon as it is unplugged. Do I need a new battery?<br /> <p><b>A.</b> It looks like you have a bad battery. Here are some behaviors typical for a dying laptop battery:<br />1. The battery charges normally (according to the battery icon) but as soon as you unplug the laptop, it dies almost momentarily.<br />2. The battery charges normally. When you unplug the laptop, it discharges normally until some point and after that point starts discharging very fast. For example it might take 10-15 minutes to discharge from 100% to 80% and then it discharges from 80% to 0 for 2-3 minutes. <br />
on Mar 15, 2011 | Computers & Internet
Tip
on Jan 17, 2011 | Computers & Internet
My hp dv5, keeps showing 0% charging,plugged in, after discharging completely, ppls wht can i do 2 make it charge?
The Battery or AC part may be faulty or broken, in these cases contact HP - their number is on the website or on your Computer Help and Support.
Dec 27, 2008 | Computers & Internet
Tip
Q. While turned on, the laptop will switch to battery power even if connected with the AC adaptor (sometimes during boot-up, or after a while) until the battery drains out, he then goes to hibernation (the battery light is off). If no battery in the laptop, it will shut down, and the AC light will blink very fast. The battery (li-ion) will only charge up to 10%, where it then jumps right up to 100%, and will discharge from 100% to 90% then jump to 0%, go to hibernation, and fails to complete the process, shutting down. The adaptor makes a small “camera flash charging” sound, stabilizing at 19v. When charging, it repeatedly makes the “charging sound” Faulty AC adaptor? Or Faulty battery? Or Both?
A. First problem: The laptop switches to battery power even with connected AC adapter. Most likely you have a faulty power jack. It’s either broken or loose. It’s a known issue with laptops and you can fix it by replacing/resoldering the power jack or relocating it outside laptop case.
Q.The yellow light for battery charging does not go even after switching the laptop off and power jack is disconnected. Battery does not charge at all with power source connected.
A. First of all, try reconnection the battery if you haven’t done it already.
The battery plugs directly into the connector attached to the motherboard. If the battery charging light stay on even when the power adapter is unplugged and the laptop is switched off, it’s either bad battery or something is wrong with the motherboard. The only way to find the culprit is testing the laptop with another known good battery.
Q. Bought a Laptop without AC Adapter. I noticed it would charge the battery OK when the laptop was off but once in windows it would not charge the battery.
A. This is very important to choose the right AC adapter for your laptop. The output voltage MUST be exactly the same. If your laptop requires 18.5V you must use 18.5V adapter. The amperage should be the same or higher. If the laptop requires 4.74A adapter, you’ll have to find an adapter which provides 4.74A or MORE.
Q. While using AC adapter alone or battery alone, laptop works. However while using them together, laptop LED lights blinks and the power meter for battery drops down immediately to 0% critical level, whereas the battery LED indicator says it’s full. I tried to unplug the AC adaptor while it went down to 0%, then the power meter for the battery came back to normal 85%.
A. There could be a few different reasons why it happens:
3. If you still experience the same problem even after upgrading the BIOS and reinstalling Windows, most likely you have a problem with the motherboard. Apparently the charging circuit is not working properly. I assume it’s not a problem with the battery. You’ll have to check the motherboard in this case.
Q. When I use only on battery, from 100% to about 40% the battery discharging normally (last about 1 hour) then suddenly from 40% it drop directly to 2%.
When I plug the AC cord, it won’t directly charge (the charge LED is still not on). After 10 to 20 minutes it then starts to charge the battery (the indicator say that it can be charged to 100%).
If I turn-off the laptop and then charge the battery, it won’t also directly charge but the delay is much shorter (maybe just about 1-2 minutes).
Is this the sign of a bad battery (when hot it can’t be charged?) or maybe a bad AC adapter (not enough power to charge the battery when the laptop is turned on?)
A. From the first part of your complaint description I can see that you have a bad battery. The percentage might vary, but the process of discharging is the same – the battery discharges fine until some point and then the remaining charge suddenly drops to the minimum. You’ll have to replace the battery.
I’m not sure about the second part. Probably it’s a battery related problem too. Just in case check if there is a newer version of BIOS available for your laptop. If you find one, upgrade the BIOS.
Q. When I unplug the power it will run off the battery, the battery icon says it is 100% charged and I have 2+ hrs remaining, but within a few minutes I get the “critical battery level” message and it will die. When I plug it back into AC power the battery charge light comes on (and will remain on for over a hour), but I will have the same problem with it dying as soon as it is unplugged. Do I need a new battery?
A. It looks like you have a bad battery. Here are some behaviors typical for a dying laptop battery:
on Jun 12, 2010 | Computers & Internet
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Battery charging status remains constant (not increasing)
I've have seen a number of different batteries do this, and I recommend what is called 're-conditioning the batteries. Do this by running the battery completely down to 0%. Then do a complete re-charge of the battery to 100% (if possible). If it charges to 100%, run it completely to 0% again and then recharge it. If it does not charge to 100%, then you may have a faulty or old battery which will need to be replaced. The AC adaptor and battery have circuitry in them and might be retaining incorrect info in them. They can be reset by unplugging them for a few minutes and then plugging them back in. There might be a specific sequence of what to unplug and when, in order to reset this circuitry. Try a couple of them. (ie. Battery, AC adaptor in to battery, AC adaptor into the wall, etc.)
Let me know what happens. Binary Bob
Nov 10, 2008 | Dell Inspiron 6000 Notebook
Battery wont charge
The batteries are probably worn. Age, failure to completely charge, frequent discharging to below 50% of charge, completely discharging, and heavy use all contribute to wearing out a battery. The most common symptom is the one that you have; the battery will not completely charge.
Nov 02, 2008 | Pride Health & Beauty
My Battery is not working!!!!!!!!!!!!!
Discharging the battery will not harm the battery. Lenovo purposely has an annoyingly slow recharge rate because a quick recharge will shorten the life of the battery. It is not a problem if you have the patience to allow a long recharge. Otherwise spring for a second battery for quick replacement when AC power is not accessible.
May 05, 2008 | IBM ThinkPad X60 Tablet PC
HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
