Question about Linksys A+G WRT55AG Wireless Router
Router lights not coming on at all?!!!
Hi...I just purchased a Linksys WRT55AG router, and i've gone through the whole set-up process, which seemed pretty basic, but nothing is happening. Nothing is lit on the router, not the power light...nothing. I thought that the problem might be in the power cord or outlet, but i tested both and both are working properly. Is this a faulty router?? I'm so frustrated!
  • amber noneya
    amber noneya Jun 17, 2007
    yeah, i'm just gonna have to return it. I went through the set-up 3 times just to make sure everything was connected correctly, and tested all the wires (which were all functioning properly). it's cold, no power light...
    this makes me question returning it for another linksys, or getting a different brand.
I have two issues:
1. The wireless router will fail in the transmit mode on G but my VoIP connection (vonage) plugged into one of the routers ports works.
2. Vonage device loses connection...I pull the power cord, wait 30 seconds and plug power cord back in...Looking at the wireless router WRT55AG as the Vonage Device (Cisco ATA 186) is booting up it causes the WRT55AG to continuously reboot until I unplug the Vonage Device Power or unplug the ether net cable to the router..Both the WRT55AG and the Cisco ATA 186 have been flashed with current firmware versions in the past month which was thought to cure the problem but it continues...Vonage Support pointing fingers at the Wireless Router as the problem.....Frustrating on both issues...Anyone have a similar problem or fix...
Posted on Feb 21, 2008
    New Friend:
  • 83 Answers
Could be a faulty transformer,,,,is the transformer stone cold or warm to the touch? i would exchenge for another
Posted on Jun 16, 2007
SOURCE:
I neeed to open my 6 ports so i can play xbox live!
Here I have given a link so that you can open the ports for your xbox in your router .
http://portforward.com/english/routers/port_forwarding/Linksys/WRT55AG/ICUII.htm
If you do not have the port numbers, its here for Xbox
UDP ports 88 ,53 and 3074
TCP port 3074 and 53
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Dec 29, 2010 | Linksys WRT55AG Router
My linksys a + g wrt55ag wireless router is having problems : It keeps restarting on its own every few seconds. ( lights go on then after like 2-3 sec it restarts and does it all over. I tried reseting it...
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Oct 05, 2010 | Linksys A+G WRT55AG Wireless Router
I need to reset the password in my Linksys WRT55AG, how Ido, please?
you need to reset the whole system for you to be able to reset the password,there is a button at the back of it where you can insert a pen to reset it,you can also try to contact tech support for linksys
Jun 28, 2010 | Linksys WRT55AG Router
My WRT55AG Linksys Router does not work. I tried doing the setup (from the CD) again. After Step 7 (cables now all hooked up) I'm suppose to get a password screen to key in "admin". Instead the lights...
Router setup
If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPPOe.
Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2009 | Linksys A+G WRT55AG Wireless Router
Missing wireless network
You have reset your router.SO you will have to configure it again to get the internet working.To do that please download the user manual from the below link and follow the steps mentioned to setup the internet.Everything is explained in detail with the pics:
http://safemanuals.com/user-guide-instructions-owner-manual/LINKSYS/WRT55AG-_E
Apr 09, 2009 | Linksys Wireless-G Broadband Router
WRT55AG router- wireless lights blink on and off and no ethernet?
If you plug in computers on the ethernet ports and they dont light up at all but you are sure that the cables that you are using works as well as the ethernet port on your computer that means that the unit is already defective. You can contact 8003267114 for replacement if its under warranty
Mar 06, 2009 | Linksys A+G WRT55AG Wireless Router
Static routing "Advanced Routing" on Linksys WRT55AG
Any reason why they're not both on the same subnet?
Jun 15, 2008 | Linksys WRT55AG Router
Two Problems with Linksys WRT55AG
You might want to see if it is a cordless phone if it is interfering with the router? If they are at the same frequencies they can interfere with each causing each other not to work.. I have had that happen to my Linksys phone and Router
Feb 21, 2008 | Linksys A+G WRT55AG Wireless Router
Getting better signal quality on wireless network?
Under the tab 'wireless' find the strint that says 'Channels', and change to another one (anyone) and then give it a day to see if you lose connection, if you do, go back and change it again. Try downloading the latest drivers and software. The WRT55AG and WRT54AG are known to drop signals. These routers are like cell phones, you have to find a good spot for them.
Jun 30, 2007 | Linksys A+G WRT55AG Wireless Router
Lights not lit on router??!! Brand new!
as long as you have connected your powered up modem to the rear port of the router and set it up firstly through the RJ45 cable and it is plugged in, then the power light should be on, if no power light then nothing is going to set up, so as long as you know you have followed the instructions, it must be a faulty unit, but go through everything again, as you may have missed something; as we all do at times.
Jun 15, 2007 | Linksys A+G WRT55AG Wireless Router
Open Questions:
~~AmaZon PrImE ReFunD PhOnE NuMbER {+1-85O-812-4OO9} USA Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon.
Oct 20, 2019 | Amazon Computers & Internet
See all Linksys A+G WRT55AG Wireless Router Questions
Linksys A+G WRT55AG Wireless Router Logo
182 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
