Question about D-Link DI-804HV - 4-Port Broadband VPN Router DI-804HV - 4-Port Broadband VPN Router [ DI-804HV ] (109528)
Vpn client Is this compatible with software VPN client in any version.is it firewall/router/switch? pls help....thanx
  • 54 Answers
This router has built is VPN software that allows VPN from anywhere in the world. There would be no need for a software based VPN
Posted on Jan 15, 2009
Hello. It appears my router is blocking VPN access to the office server. I can connect using the ethernet cable so have isolated the problem to the router firewall. How do I get around this? Thanks
Hi
I will make a couple of assumptions on you setup. First, you have some type of highspeed internet. You have a retail type router/firewall plugged into your internet modem. You are using a VPN Client software installed on a PC or Laptop. By stating that when you connected using your Ethernet cable, you were plugged directly into the Internet modem.
Basically, what you have here is a configuration issue with your Router/Firewall. I use the Cisco VPN Client Software from home. This software uses UDP over TCP port 10000. Your VPN Client will use something along this line as well. So, you need to do one of two things here. Determine what Protocol and Port your VPN software uses. Login into you Router/Firewall and add that to your outbound allowed traffic. Or login into your Router/Firewall and configure it to allow all outbound traffic.
If you are not sure how to do this, the documentation that came with your Router should contain a Tech Support number to call. They can walk you through this in short order. Otherwise, post your EXACT make and model of your Router/Firewall and I will try to get the information for you.
Hope this helps.
Brian
Jun 30, 2010 | Linksys Computers & Internet
I have Timewarner cable and can't set up a vpn so that a client can connect into my Lynksys vpn router. Is it possible that the firewall in the TW router is blocking a client or that maybe I need a static...
No you need not buy a static address... just forward these ports in linksys router...
50 both TCP and UDP 51 both TCP and UDP 500 both TCP and UDP 10000 both TCP and UDP 1723 both TCP and UDP 1701 both TCP and UDP
also disable firewall in linksys router....
May 10, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
I had to reload my Cisco VPN client software after a system upgrade. I can no longer connect using VPN on my KR1 router. Any suggestions?
What else changed during your system upgrade? May be OS or AV software blocking the connection. Try stopped all AV and firewall services.
Jun 08, 2009 | Kyocera KR1 Wireless Router (TXRTR10000)
Vpn client
You can download the MU VPN client at www.watchguard.com/support
For instructions on how to install and set it up, this document should be helpful http://www.watchguard.com/help/docs/v50SOHOMUVPNGuide.pdf
Nov 05, 2008 | WatchGuard Technologies WatchGuard Firebox...
VPN connection issues
check if you can enable "VPN pass-through" on your home router.
try diabling its security features (firewall) one at a time and try afterwards.
last option perhaps try upgrading to the 5.06 version of the vpn client.
Apr 06, 2008 | Linksys -Cisco Wireless-G VPN Broadband...
Router is blocking my VPN client
I have the same problem with the Cisco VPN client, but when I turn the firewall off on the SBG900 it works fine.
Feb 20, 2008 | Arris SURFboard SBG900 Wireless Router...
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Open Questions:
Computers & Internet Logo
628 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
