Question about Ricoh Aficio 3025 All-In-One Laser Printer
Switched from a PC to a MAC at work and  now the computer cant print... i pt in the correct ip adress, and name, but now it just prints pages with nothing but sybols on them.   do you have the driver i need for a Ricoh Aficio 30225?
  • 58 Answers
You need to purchase a postscript option, there is no other to print from a mac.
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
Tip
Configure PS121 with MAC OS X
Configure NETGEAR PS121 print server with MAC OS 10.4.X and may work for other version of MAC OS X
Please sure that the printer is working in direct connection with the computer.
1. Now connect the printer to the USB port of the printserver and then the ethernet cable from the router to the Printserver ethernet port.
2. Press the diagonistic tool button on the printserver for 10 sec (All the lights will blink amber), you will recieve a print page with Port name,Ip address of the printer and other details.
3. The ip address will be given from the router,If no ip address, powercycle the router, printserver and the printer. Press the diagonistic tool button again.
Open the System Preferences
Click on “Print and Fax” icon
Click on the “+” icon to add a new printer
Click on the “IP Printer” icon
Select “Line Printer Daemon – LPD”
1. In the Address field, enter the IP address of the PS121
2. In the Queue field, enter L1
3. In the Name field, enter L1
4. Select the printer manufacturer from the pull down
5. Select the printer model from the scroll box
6. Click Add
a. Click once on L1 to select it
b. Click on Printer Setup
Click on the “Installable Options” pulldown menu and select “Name & Location”
1. Change Printer Name to IP address of PS121
2. Change Location to: IP_.ip of PS121
3. Click on Apply Changes
The Macintosh is now ready to print.
on Mar 18, 2010 | NetGear PS121 Print Server
How to setup the network settings of my lexmark e120n printer. I installed the printer. Printing tasks give a "not abble to print "message. I can give it an IP adress and print a document from...
Check the network cable that connects the printer and the router. Please print a network set up page to check if the status shows connected under tcp/ip. To print a network set up page please click the link http://bit.ly/qTSoRt, please make sure that the correct print driver is installed on the pc.
Please take note of the IP address and type it on your browser
Apr 30, 2011 | Lexmark E120n Laser Printer
I have a Aficio Ricoh 3235C I need to delete a name from my scanner address book. I can not figure it out for the life of me. Any help would be appreciated.
print off config page for the ip adress
log on to copier via the ip adress through ur web browser
user name is admin no password
go to address book then delete
Nov 09, 2010 | Ricoh Office Equipment & Supplies
I have one Epson TMU220PD printer. I have to set its IP address. how can I do it. Also, i want to know its default IP. Thanks, Saket
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Oct 23, 2010 | Epson TM-U220 Matrix Printer
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
I cant get the wep key and i try to put the ip adress in and it wont come up
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that
computer.
router set up page is the page where you can check all the
router settings.
Click Here for more information about the routers and
network
Apr 25, 2010 | Belkin (F1UP0001) Print Server
Trying to setup tcp/ip settings on my hp laserjet 8150 series printer
First, make sure your Network Interface is working properly. Print a test-page. Menu--->Information------->Print configuration-page. If your machine print only one page, your interface doesn't work right. If your machine prints a configpage and a seperate network-page, you're good to go.
The easiest way is to look at the network-page and see if the machine already got a ip-adress. If it already got a ip-adress (DHCP), type that adress into your favorite web browser and do your config from the machine's web-interface.
Or you can access the printers menu.
Menu---->I/U---->EIOx settings---->TCP/IP----> and set your settings as you wish. Good luck.
Dec 14, 2009 | HP LaserJet 8150dn Printer
I cant install konica Minolta bizhub C351 on my mac. please HELP
To print via IP on MAC  type IP address in queue type print ,name the printer and  the correct driver/ fy...35/
Mar 13, 2008 | Konica Minolta bizhub C351 All-In-One...
Emulex NetQue Pro2 Print Server how do I connect to it
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Ricoh Aficio 3025 All-In-One Laser Printer Logo
73 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
