Question about HP LaserJet 5000 Printer
Laserjet 5000 printer A4 size printing right side line not printi
Laserjet 5000 printer ,A4 size page printing time , right side line not printing .why?
  • bins_koshy Jan 15, 2009
    printer configuration page printer self test time also same
    printer not connected to pc.printer self test time also happend ,pls help me
    Sergeant:
    Champion:
  • 246 Answers
Try to set the margins
Posted on Jan 15, 2009
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
Tel me the processedure of duplex printing
Dupoles printing can mean different options in different hardware and software. It can refer to two pges condensed to one A4 in landscape or it can mean odd and even pages on two sides.
Most office suite packags give you the option of duplex in the same way leaving the hardware unchanged which is the best option oveall.
You can printy all ODD pages then reinsert and have it print even pages on the other side and then all you do is colklate them. OR you can print side by side fromn 1- whatever.
By using software option it leaves the printer in its native mode without having to reset ity for the next job
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | HP LaserJet 4250dtn Printer
HP 4L when printing an internet page, print size is for
Under print preferences set the paper size to A4.
Start > Printers and Faxes > (Right-click printer and select properties) > (select printing preferences) > (set paper size)
Aug 25, 2009 | HP LaserJet 4 plus Printer
Load A4
A4 is for european size, if you are printing on a letter size this is a mismatched.
you need to change your files printer properties to A4 or letter size, or change your printer paper size.
better yet cancel this document and send it again , this time by checking the printer properties was set to your desired paper size
Jul 28, 2009 | HP LaserJet 2840 Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
Hp4650 printing BLANK pages
Try printing a configuration page to see if that comes out. If it does then you might have a print driver problem. Also try printiing a test page from the printer properties on that printer.
Mar 30, 2009 | HP LaserJet 4650 Color Printer
Laserjet M1120 mfp does not print on legal page properly. But it prints on A4 size paper properly
go to printer settings and change the settings according to the paper size of your page.
Feb 08, 2009 | HP LaserJet M1120 MFP All-In-One Printer
HP laserJet 5000 Printer continually printing same page
laserjet 5000 printer A4 size printing right side line not printing .why?
Jan 14, 2009 | HP LaserJet 5000 Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
HP LaserJet 5000 Printer Logo
112 people viewed this question
Seeker5211
Seeker5211
