Question about Packard Bell FT500 15" LCD Monitor
Monitor shuts off but green light stays on I have had the features, screen resolution, downloaded updated drivers from dell, and viewed dells troubleshooting advice on the monitor cd that came with the computer.
  • 30 Answers
Odds are that you have your power saving setting a bit high. (or the monitor is poopy)
Your compuer will go into stand-by mode on it's own.
Go to Control Panel and Power Options and set them accordingly.
If this does not work then congrats!!
You purchased a DELL!
http://support.dell.com/
Hope this helps.
Posted on Jan 15, 2009
LCD monitor turns off
I have had the same problem as others seem to have had with the dell flat panel. After leaving the screen on for some time, the monitor brightens for a moment, then goes black, while the green light stays on. When I reboot, it works again for some time, or if I remove the cable for a few minutes and plug it back in (with monitor turned off) it will come back on...only to repeat the black screen. I have changed the power features, screen resolution, downloaded updated drivers from dell, and viewed dells troubleshooting advice on the monitor cd that came with the computer. Nothing directly advises on this problem, but I have read here and in other online message boards the exact same problem. Anyone able to fix this?
Nov 02, 2012 | Computers & Internet
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
Dell E177FPB monitor has ghost images "bleeding"
I had dual monitor with color bleed to the right. The solution was
1) identify optimal resolution for both monitors ( Dell 198wfp @ 1400 x 900) and (Laptop @ 1200 x 800) 2) check colour setting (32 bit or 16 bit) 3) reduce colour setting down to 16 bit) 4) Check performance 5) reduce screen resolution 6) check 7) cycle between screen color and screen resolution 8) if no luck, check updating the drivers for graphic card 9) if no luck, check updating monitor drivers 10) if no luck, check altering memory set aside for graphics (onboard memory for example or off-graphics-chip-on-RAM-memory) 11) Monitor checking software is very helpful : try "http://majorgeeks.com/download.php?id=22" for the Nokia Monitor Test (a CRT tester) or any other freeware/shareware testing program such as passmark's products etc.,
You might just have to suffer with a large workspace and mungy grapics performance though ... I am.
Nov 22, 2010 | Dell Computers & Internet
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Screen resolution driver
Download your drivers from DELL here;
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_PNT_P4_GX260
Please vote 4 thumbs up for me!!!!
James
Apr 27, 2010 | Dell OptiPlex GX260 PC Desktop
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
The screen resolution will not change. One some computers this happens on, it is stuck at 800x600. Others, 640x480. Some are even stuck at 1024x768. The slider is movable and shows all available...
Seems to be a common problem: Here's one possible solution: http://ask.metafilter.com/76449/Dell-notebook-Vista-and-Screen-Resolution
I recommend you search the Dell forums, as they are likely to have received the most complaints and if there is a workaround someone will have posted it there....
May 02, 2009 | Dell XPS M1710 Notebook
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
I perhaps can. I would think inverter or ccfl's.
Jun 12, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Packard Bell FT500 15" LCD Monitor Logo
359 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
