Question about Akai LCT2701TD Television
Missing capacitors? Hi Bill, It's me again. I'm still trying to fix the MLT166A power supply myself. After staring at it for a while, I noticed that there were a few "empty" places on the circuit board where it seems like capacitors should be. These are namely: - EC3 (100microFarad, 35V) - C54 (470picoFarad, 1000V) - EC12 ( 1000microF, 16V) Isn't it a bit odd that these are missing? Or is it typical that some capacitors are left out for some reason? I'm planning to replace these and see if that will bring the TV back to life. What do you think? Below is a diagram from the manual I got at http://esi.fox-international.com/ It shows capacitor C54, but with letters "NC" under it, instead of "471/1KV" like I think it should. Any ideas about what NC could stand for? As always, your response is greatly appreciated.
  • mrkrypto13 Jan 16, 2009
    Bill,
    Your answer is a bit confusing... what do you mean by "the requirement was replaced with an opposing cap"? The place where C54 is supposed to be is unoccupied on the circuit board. What about capacitors EC3 and EC12? Should the TV be able to function without them, or should they be replaced?
    Kris
    Diagram showing EC3:
    Diagram showing EC12:
  • mrkrypto13 Jan 17, 2009
    Thank you for the thorough explanation you provided this time. This is the answer I was looking for!
    I believe my rating for your previous response was reflective of how much value I got from it, as it only addressed a small part of my question, and was worded in a very confusing manner.
    The reason why replacing the smps is not a viable option is because they are no longer being manufactured, and are virtually impossible to find. By the way, isn't the point of being a DIY'er to attempt to repair things instead of simply replacing them?
    I definitely appreciate your help and your responses, which overall are useful. Even if I'm not able to successfully complete this repair, I hope this will be useful to someone else who might be attempting this fix and thinking of the same questions.
    Kris
  • 934 Answers
NC in the schematic is a NP (Non-polorized film Capacitor) each C6, C7 and C54 of the schematic above are NC caps as opposed to polorized electrolytic caps... Since the value isn't printed the requirement was replaced with an opposing cap, in this case with a polorized electrolytic instead. It is common to see these design changes and see them still noted in the schematic because they appear on the board. This usually happens when it was too late to correct the board or more costly to redraft the board to eliminate the pos#...
Bill
Posted on Jan 16, 2009
  • William Rayburn
    William Rayburn Jan 16, 2009
    The circuit ends at C53 with the use of two resistors R103 and R132 that's simply an after thought in the design and C54 was eliminated, but probably not before they had sent the thousands of boards to be etched... So it will appear on the schematic but with no value - - because nothing goes there..
    As for EC3 - - Q9 triggers to ground at R29, should be no reason to cap this but I am surprised they didn't make R29 a fuseable resistor to ground. (more reliable).
    EC12 is a redundant EC11, both drawing ground from the backside of the transformer T2D at/near FG2. I have no clue why this was added to the design unless they were looking for a more stable test point denoted by the 8A on the positive side of EC12..
    Now Kris, I'm curious why you've rated my helping you so poorly? My suggestion to you on this was to replace the smps to repair the problem. Unlike most DIY'ers you've chosen to attempt a repair on this module and use it like a classroom project - then when I've answered you rated me as less than useful I don't get it, what part of my help are you finding useless?
    Bill
Have a LG 47LC7DF tv and its starting to have a hard time turning on. Green light flashes for 15 secs and screen lights up a little with no picture or sound. Have to unplug it to shut it off sometimes....
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this work out in solving the problem.....
Jul 05, 2011 | LG 47LC7DF 47 in. LCD HDTV
My sony kdl 40 u 2530 e is not staring properly. the red led signal blinking 4 times periodically .any idea about the problem? If i turn off tv for hours then it starts for 2 minutes and again the same...
The tv power supply board have problems and the caused,check the tv power supply board have it fixed or services by u or tv tech.most likely those capacitors parts are dying on the tv power supply board like bulging or puffing up.Take the tv aparts,check the tv power supply board that board where the power a/c cord plug into it.Carefully check for capacitors parts for bulging and puffing up on to it tops.Changes all these dying capacitors,tv should be work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 18, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hi my Olevia 32" LCD
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 13, 2011 | Olevia LT32HVE 32 in. LCD Television
Samsung LN406 1F 40inch 1080p lcd tv wont turn on, clicking etc, sometimes comes on fine after 15 min of clicking, now turns on after clicking but only sound no picture. Can I fix capacitors and power...
Apr 29, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
55' sony grand wega will not turn on. The green light blinks 5 times and then red light blinks 6 times. red light cycles 6 times again. What is the problem? Can I fix it myself?
Take care.....
Dec 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I SET THE TIME I WANTED THE MICROWAVE TO RUN AND WHEN I PRESSED THE START BUTTON I LOST ALL POWER I CHECKED THE POWER SOURCE TO THE OVEN AND HAD POWER HOWEVER NOTING ON THE SCREEN OF THE MICROWAVE. WHAT...
Hi Bill. it is possible that you may have just blown a fuse. Check the fuse and replace if it blows again check all the diodes in the power supply. If one reads in foward and reverse bias please replace dides should only read in one direction. If these diodes are not shorted check all the diode in the microwave especially the large one connected to the large capacitor. Make sure you discaharge the capacitor before troubleshooting this section because it can shock you even when the microwave is unplugged. If any diodes are shorted replace them this will fix your problem.
Nov 08, 2010 | Kenmore 80012 Microwave Oven
Akai lct2701ad will not power up
The power supply is defective if the TV fails to power up or the front light just blinks, common failure on these LCDs with MLT166A power supplies.
I repair these power supplies, if you need further assistance write to jah2mil@hotmail.com
Mar 05, 2009 | Akai LCT2715 27 in. LCD Television
50 inch plasma blank screen
I bought my Philips Magnavox 50" plasma in June of 2007. In february of 2009, I noticed increasingly longer delays in the video coming on after turning on the power and then the audio began to delay coming on. After a few weeks of this problem the audio and video then stopped coming on at all. However, there was power going to the unit because the green power light was working. I noticed over 50 other consumers on this website had the same problem. WITH THE HELP OF OTHERS ON THIS WEBSITE, I HAVE FIXED THE PROBLEM FOR $40. YES, FOR LESS THAN $100.00 I HAVE A WORKING HDTV AGAIN, BUT WITH NO THANKS TO PHILIPS - MAGNAVOX. THEY WERE USELESS.
HERE IS THE FIX:
1. Unplug your power supply cord.
2. Remove back panel on your HD.
3. Look for capacitors that have a bubbled or slightly raised and rounded top. This indicates the capacitors have overheated or leaked and need to be replaced. The normal look is a flat surface with no raised features at all. (I had two bad capacitors that were side-by-side and identical: 3300uf 10v. Also, they should be located on the power supply board. My power supply board is in the middle of my 50" plasma.)
4. Go to an electronics repair store or Radio Shack and see if they carry your capacitor type and size and replace them yourself if you are comfortable with removing the capacitors and soldering new ones to the power supply board. The capacitors will cost you $2.00 each or less.
5. I was not comfortable replacing the capacitors myself so I removed the power supply board by removing the screws and unplugging several wire connections. This was not difficult at all. I then brought the power supply board to a local electronics shop that did repairs on HDTVs and simply asked them to remove the bad capacitors and solder two new capacitors onto the power supply board. They did it for $40, which included cost for the 2 new capacitors, while I waited and it only took about 10 minutes.
6. I replaced the power supply board and back panel of TV and it worked!!!
Some people on this sight suggested replacing the capacitors with some that have higher temperature ratings. Based on that advice, I wanted to replace my two that were bad (3300uf 10v) with two rated at 4700uf 35v, but my electronics guy suggested against it. Instead, I replaced mine with 3300uf 50v, with the only difference from the original parts being the higher voltage (50v instead of 10v). I figure if the problem occurs again, I now know I can get it fixed for less than $50.00. Philips - Magnavox should be ashamed for such poor customer service and not telling people about this simple fix. When I called their customer service support number I was simply directed to a repair place --over two hours away!!!
Jan 22, 2009 | Philips 50PFP5332D 50 in. Plasma...
No power up on polaroid flm3732
I had this problem and fixed it myself. I posted some vids of it on youtube. You can either search flm3732 repair or go right to my page youtube.com/raider2845 Hope it works out for you.. Good luck
Oct 19, 2008 | Polaroid FLM-3732 Television
BEEPS
Needs a power supply - - MLT166A only available at Fox International..
Bill
Oct 17, 2007 | Polaroid FLM-2601 Television
Televison & Video Logo
816 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
