Question about Microsoft Windows Vista Ultimate Edition
UNABLE TO UNINSTALL PROGRAM
I installed smartbro usb modem in my vista home basic computer. Then i uninstalled it but it did not uninstalled properly. I want to install it again but i couldnt. My server said i have to uninstall it properly. I did several times, but this message appeared.
an error (5005: 0x80070002) has occurred while running the set up. Please make sure you have finished any previous setup and closed other applications
  • 55 Answers
You probably uninstaled it, but didn't remove it from the registry properly... try searching the registry on: Start > Run and type Regedit, and go to search, and type SmartBro... yuste delete those keys and reboot...
warning! backup your registry before you make any changes!
Posted on Jan 15, 2009
I can't uninstall Microsoft office 2013. When I click on uninstall in programs and features my machine starts gathering the files to uninstall and it fails to uninstall.
one option is to install a third party program like revo uninstaller to force uninstall the program.It can also be due to slow computer.Please let us know what operatiing system are you using
Oct 17, 2015 | Microsoft Windows 7 Home Premium 64BIT...
I ALWAYS GET AN ERROR UPON USING THE ROUTER TO MY SMARTBRO BROADBAND INTERNET.
because you have not stated what the error code is unable to point you
if you are referring to your internet connection
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
also you might check
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
check the leads from the modem/router whether usb ethernet make sure they are not bad/faulty and have secure connection
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Apr 28, 2011 | Computers & Internet
Laptop Toshiba L501 win vista home premium got problem RAS error code 608 when use with vodafone internet model K3765. This internet key work with other laptop run xp or vista... Could anyone please tell...
Error #608
Error Message: The device does not exist.
Solution:
1. Check that the right modem is set in the dialer
2. Ensure that you are using the right modem drivers by checking the modem diagnostics. If it’s not the case, set up the correct drivers.
3. Remove and install the dialer again
4. Your modem might not be working properly; try to install it again.
5. You should then consult your computer manufacturer if the problem persists.
Apr 12, 2010 | Computers & Internet
I keep getting a rundll error i am unable to run internet expoler
This problem could have happened due to an incorrect program removal procedure. You can hence try to fix it by installing the program that has been removed and to correctly uninstall it either with the Uninstall option proposed by the program itself or through the Add/Remove feature found in the Control Panel menu.
  • 1. Go to the Start menu and open Control Panel
  • 2. Select Add/ Remove program option and locate for the program that you want to remove and click Remove.
  • 3. When the procedure is over, delete any shortcuts that could have stayed and empty the Recycle Bin.
  • 4. Reboot your system
Jan 31, 2010 | Microsoft Windows Vista Home Basic Edition...
How do I uninstall the program software for HP OFFICEJET PRO L7500 (have installed a copy by mistake) on Windows Vista
Go to Control Panel - Program Updates- Locate the program in the list then click on it and select uninstall from the popup window.
Oct 07, 2009 | Microsoft Windows? Vista Home Premium...
Under control panel add and remove, i have a
download revo uninstaller from this link
then install in computer then run it then sleect program which you want to uninstall remove also registery key it ask you for that.
then it uninstall from your computer.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Let me know if you have any confusion.
Thanks.
Jul 16, 2009 | Microsoft Windows Vista Home Basic Edition...
Vista home basic and 3G modem installation
The 3G Device is actually two devices in one. It is a portable storage unit and a 3G Modem. Once the cdrom driver is installed you can go to my computer and it should show up. you then go into the cd drive which has appeared and run the setup program to install the 3G Modem Driver. That is the way they designed it.
Jun 06, 2009 | Microsoft Windows Vista Home Basic for PC
Why wont wizard uninstall print shop 15
Dear the uninstall wizard is basically a program to remove the files of a specific software from the system, the uninstalled wizard is disturbed, thats why is unable to uninstall print shop 15. You need to reinstall it in order to make corrections to the uninstall wizard. or need to install the operating system again.
Best regards.
May 18, 2009 | Computers & Internet
MY USB HSDPA MODEM WILL NOT WORK WITH VISTA HOME PREMIUM SP1
Be sure your system meets the minimum System Requirements.
• Standard USB interface
• Microsoft Windows® 2000, Windows® XP or Windows® Vista
• Mac OSX 10.3.7 up to Mac OSX 10.5 32 bit version
• Minimum 50MB of free hard disk space
• Minimum 128MB RAM
• Microsoft Internet Explorer 5.5 or higher
Uninstall or reinstall SP1. Like Windows XP, Vista will not be reliable until SP2.
If you are using the USB modem via a PCMCIA USB 2.0 adaptor, then you will have a power issue. The PCMCIA cannot supply enough current to properly initialize a USB mode (500mA). You will need to get your self a powered hub or get yourself a HSDPA mobile.
Aug 31, 2008 | Computers & Internet
Unable to cnnect internet on vista home basic
check the NOKIA site for compatibility issues for VISTA. VISTA has compatibility issues with many softwares (which may include the improper driver for your N 72)
May 24, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
224 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
