Question about Neovo F-417 17" LCD Monitor
LGM578RIO1OOGRNAO-TO2, have this box with the letters showing at
LGM578RIO1OOGRNAO-TO2, have this box, with these letters showing, with what looks like the monitors resolution, brightness, etc, etc.......in the center of the bos there is the White Balance in pink letters, second line reads .6500 9300, third line reads Auto, 4th line Brig Dsp1 and the 5th line read Dsp2 DSSC in the bottom right of middle box in Factory..........what is this, how do I remove it, cannot access it with my mouse...........
  • walsh_jkl Jan 16, 2009
    the buttons are not working, I thought of that, and when I press these buttns nothing happens??
    it is a F-417 Monitor
  • 30 Answers
There should be buttons on the monitor that will help you with menu issues if you don;t have a remote for it.
You also might want to Google the correct monitor,, as the one that you posted does not exist.
Posted on Jan 15, 2009
  • Marc Bradley
    Marc Bradley Jan 16, 2009
    These monitors come with a driver cd. try to reload the driver.
    (The menu button could also be broken which would mean it goes back to where you bought it.)
When composing or fwd, my contacts window shows the contacts and I can select but they do not appear in the address line. Also the contact window shows a XX upper right corner.
No sure which email you use. But two way first open compose, in to box. type the first letter on name. And all listing with that letter will show. click on the one you want. Also go to contact list and click on there name, should bring up your letter page.
May 23, 2017 | The Computers & Internet
Model #NGD7200TW starts up again after drying cycle stops
TO CHECK ON YOUR PROBLEM YOU CALL AMANA OR WHO THE NAME BRAND .< 1 > GIVE THEN THE MODLE NUMBER / SREAL NUMBER .< 2 >GIVE THEM THE CODE THAT YOU SEE "4" . LOOK VERY CLOSLY AT YOUR DISPLAY AND SEE IF THERE IS A LETTER YOU CAN MAKE OOUT. THIS INFO WILL HELP GREATLY.
Dec 10, 2015 | Amana Dryers
Cd/dvd drive does not show up in my computer. immediately opens when i close it. does not read discs
Go to my computer icon, right click manage, go to near the bottom look for disk manager, if u dont see ur CD drive then try connecting and disconnecting it. u can also try go to start> run. click run then in the text box type cmd then press ok. in command promp, type 'x:\' x is ur drive letter, so if ur drive letter is d type 'd:\', if nothing shows then there might be a problem but its unlikely that its a hardware issue.
thanks and Regards
Trinoj
Aug 05, 2011 | HP Pavilion a6603w PC Desktop
The drive is detected normally by the driver, no problem with the driver,the green light comes on, by touching it feels running normal, but does not show recorded data, nither makes icon in my computer...
Right click on my computer and select manage, in the box which appears select disk management, in the next box that appears, look in the bottom right hand panel, you drive should be lised there if it is picked up by the pc, you may need to initialise the drive (the option may appear automatically) or you may just need to give the drive a letter, right click the drive in question and select change drive letter or path, in the next box click change then use the drop down to select a letter. Only available letters will show, make sure you dont select and change the drive letter for your boot drive though, because you will completely mess up your computer.
May 03, 2011 | Samsung Spinpoint M5 HM121HC 120 GB...
How to unlock a sandisk cruzer usb flash card 16 gb
If you cannot open your usb drive, you will need to open your drive management. Sometimes, drive letters that the usb drive looks for, usually F, G or H, are taken by other drives. You can change drive letters on other network drives to different letters, therefore, allowing the usb drive to access the letters it is looking for, and effectively, unlocking it. Below are directions on using the Disk management utility in windows:
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility. Also, drive '0' is usually your main hard drive.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
Jan 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
On certian channels a big black square pops up and random letters start going across the screen.
Ur tv Closed Captioning is still on like CC 1,2,3 or Text 1,2,3 is on.Look in ur remote control for a button said CC press it make all CC 1,2,3 to all off.Go into memu find closed caption function Text 1,2,3 turn it to all off.These steps,will stop random squares boxes lettering showing up ur tv any channels.
Dec 11, 2010 | Mitsubishi WD-65731 65" HDTV
When A USB thumbdrive is plugged in, it is reconized but then it doesn't show a drive letter in "my computert" in order to transfer to or from the drive. The safe eject tab is present and does give a drive...
You should plug in the thumb drive, wait for it to recognize it, and then right-click on My Computer. Select the Manage option. Inside the Computer Management window, go down to Disk Management on the right side. The left pane will show you all of your local drives (hard drives, CDRW, USB, Flash, etc...). If you see your thumb drive listed in the drives, you can right click on it and select "Change drive letter and path". This will allow you to pick the drive letter you want as long as it doesn't interfer with any other existing drive letter.
May 13, 2009 | Toshiba Satellite Pro 4600 Notebook
Maxtor basics personal storage 3200 shows up as a usb mass storage device with no drive designation letter. used to work but not after problem with win xp pro & reloading oper. syst.
press the "Start" and "R" keys at the same time.
type "compmgmt.msc" in the box and select OK.
On the left pane, select "Disk Management"
on the screen, look for the drive that does not have a letter.
Right click the bar (on the bottom part of the screen) of your drive and select "Change Drive letter and paths...".
Click add and select the "assign the following...".
on the drop down menu, select any letter you like EXCEPT A or B.
click OK.
Your drive should now show up in My Computer. All of your Data should still be there also.
Aug 23, 2008 | Computers & Internet
Rca guide plus gold 52 in projection tv
sounds like the blue CRT is contaminated open the back turn on the tv look into the blue gun if it looks snotty the coolent needs to be replaced
Oct 31, 2007 | RCA P52926 52" Rear Projection Television
Neovo F-417 17" LCD Monitor Logo
98 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
