Question about Dryers
CRACK IN DRUM
MAYTAG NEPTUNE FRONT LOADING GAS DRYER
  • Anonymous Mar 09, 2009
    LG Tromm DLG2524W Gas Dryer has a broken drum. I know that the LG is referred to as Life's Good, but what idiot thought to make a PLASTIC inner dryer drum? The model I have is not 'cracked' it is broken perpendiculare to the seam near one of the tumbling fins. I have experience replacing parts in large appliances but I cannot find a replacement part. I would prefer a METAL one...no more plastic. Any help you can give me in getting a part DIRECTLY would be appreciated.
  • 318 Answers
Unless this is less than a year old your dont have much chance of a free repair. drums dont normally crack but it can happen around a seam. did it make alot of noise and you let it go too long until now the drum is worn out and thats where the crack is at?
if you do have a newer unit then i would call maytag and let them know you have a failed drum. they might give you an authorization for part replacement, but probably not labor from an authorized servicer.
the labor might cost about 100-120 bucks, but that is still cheaper then the price of a new drum, maybe 150-175 bucks.
Posted on Jan 15, 2009
Maytag neptune mdg9700bww dont stop drying by it self
could be dirty electrodes, find the two shiny metal strips in the dryer drum maybe in the front, so you will stick your head in the drum and look back at the lint filter to see them. Clean these with window cleaner and try again.
Jan 22, 2014 | Maytag Neptune MDG9700A Gas Dryer
I have a maytag dryer and i need to know if it is electric or gas. model # (P)MDG4000BWW
Gdeli25 --
The Maytag Neptune MD[G]4000BWW is a front-loading [G]as dryer. Parts list and manual are available online from:
[http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47083]
If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer is not staying hot to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Our drier is making a clunking noise, and the barrel has developed a small crack at the front.
your door seal, front drum bushing needs to be replaced it is a felt type soft unit that is installed directly at the front of the drum just behind the front cover
Apr 28, 2010 | Maytag Neptune MDE6700A Electric Dryer
I have a neptune dryer. It is making a rhythmic
I normally only comment on Electrical Dryers, but you problem sounds like something that is common to all dryers.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, You will probably have to remove the top of the machine first, then remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
I have a neptune gas dryer. Where is the igniter located? it's model number 53-4537
take off the front of the dryer by removing the four screws right inside the dryer door the ignitor is under the drum you cant miss it
Dec 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer Drum Wont Rotate
did you check to see if the belt was not broke? if not possibly the motor went out.hope this helps
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Mar 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
