Question about Logitech Quickcam Chat Webcam
Web cam drops off line
Web camera cam drops off after a few minutes all the time I'm using skype windows XP. the other party I was talking too was on a logitech. I can not have a conversation more than a few minutes at a time
its drops completely off line. I reinstalled driver and it worked for 45 minutes last night I thought I had fixed it, So I log on today and same problem came back.
I really need help on this one.?????
    President:
  • 8,637 Answers
Normal 0 Recheck your Audio & Video settings.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 15, 2009
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Toshiba built in web cam not working
Remove both Webcam driver and skype with a software called Vista Manager from yamicsoft.
Why a third party tools to uninstalled a software?The answer is it will remove even the files or registry key that is concern with that software.
Download the file using the link below
http://www.yamicsoft.com/vistamanager/software/vistamanager.exe
If you are with windows 7 then downalod Windows 7 Manager
Here is the link :
http://yamicsoft.com/windows7manager/software/windows7manager.exe
after unstalling reboot your system.
First installed your webcam driver and check webcam work or not. Then installed skype software.
It will work.
Note: Lastest skype version have problem with webcam synchronisation.so used a little older version.
Dec 28, 2009 | Computers & Internet
I am considering buying a web cam so that when I go out of state for a couple months I can talk and see my little grandson in person. But it looks quite complicated, so I am not sure this is a good idea....
I recommend you use the Microsoft Lifecam VX-3000 or VX-6000. It is the best for getting support and drivers. It cost
around $38.00 for the VX-3000.
Microsoft cameras mentioned are good for use with all the Windows Operating Systems through Windows 7 their new Operating System.
I will give you some information you can save for future use if you buy any web camera.
Save this for future use:
Follow these instructions and your camera should work properly.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
1. Windows Live Messenger:
Go to this site http://download.live.com/?sku=messenger and download Windows Live Messenger.
NOTE: Your audio and video should work. Enjoy.
Nov 02, 2009 | Logitech QuickCam Communicate STX Personal...
Logitech Web cam freezes every few minutes when used with Skype
Look in device manager See if there is a memory conflict with another device
Jul 27, 2009 | Logitech QuickCam Connect Webcam
My cam can't view by the other party
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have there computer setup properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
B. Yahoo Setup:
Mar 22, 2009 | A4tech PK-635 Webcam
Video breaks up after a minute, within 2minutes call drops off
yes mame i need to know are you using yahoo instant messanger or skype or windows live messanger which service??RICHARDM69
Dec 09, 2008 | Logitech QuickCam Messenger Web Camera
Web cam
No.
Is's ok to have only one cam.
You can see the video from your oposite if they have a cam.
Or if only you have a cam the other party should be able to see you.
Oct 21, 2008 | Skype IM
Web cam is causing interference.
got the same -- horrible noise coming out of the speakers.
I connect XP to XP, with skype on both sides. One of the sides seems fine, but the other one (which is mine), gets this noise every minute
can anyone tell me why it is so?
Oct 18, 2007 | Labtec Webcam Pro
Logitech Quickcam Chat Webcam Logo
48 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
