Question about SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB
Last year i bought mp3 and my computer didn't have any problem
it stoped working and gave me new instead which works with usb2
my computer even can't see it , maybe because my computer is usb 1
looks like i need driver
  • 8,596 Answers
The software can be found on Sandisk's website
If the computer does not have a USB 2.0 port, it won't have enough power to successfully run the Sansa
Posted on Jan 15, 2009
Computer not recognizing sansa clip +
This is a known issue with this player and should be returned. There are lots of docs to support this just google your model # and print out and take to retailer.
Jan 27, 2010 | SanDisk Sansa Clip MP3 Player
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
http://forums.sandisk.com/sansa/
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
My player (sansa clip 2gb)won't read tags (artist, album ...)
You check your songs from your computer first; Right click on one of songs, select Properties, select Summary tab (check Artist, Album Title, and Title). If they are there, you should update new firmware (search SANDISK FORUM from google). If they are empty, it's right for device display the filename.
Jan 18, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip will not turn on.
hey dude something is lose inside it has no connection to the battery but the actual port that you plug your pc in does ... myn is also like that and iv had it for a year now,,,,
Jul 09, 2009 | SanDisk Sansa Clip MP3 Player
My pc wont let me install new sandisk 2gb mp3 player
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
Hope this helps!
Apr 02, 2009 | SanDisk Sansa Clip MP3 Player
I have no manual for the Sansa Clip 2GB MP3 player
this is the PDF manual for the sansa clip Please Click Here that will let you download manual you will need adobe PDF reader and thats easy to find online
Mar 27, 2009 | SanDisk Sansa Clip MP3 Player
My battery won't hold a charge
Let me put it this way - you are not supposed to replace your battery - it will void your warranty. Call sansa and find out if you can get an in-warranty replacement. If you want to be a DIY daredevil, you can twist the clip until the area behind the clip pops out - read the battery specs and order a battery online. But really, I would get an in-warrnty replacement or buy a new one - the price has dropped from 60-70 last year to about $25-30 this year.
-Tha Mp3 Doctor
Dec 22, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player driver 2GB
The drivers and all software is available from Sandisk's website.
Oct 23, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player 2GB shows as UNKNOWN DEVICE when i connect
Sandisk website will have it, and will have the vista compatible software:
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
here is the link for the sansa updater.
Ok...here is something you might want to do....I know you already formatted your device a zillion times already but please do it one more time using the Format option under Settings menu in your device....then restart your computer....then plug in your computer again after restarting to see if it recognizes now.....if not...here is one thing you could do....go to this link
http://www.nirsoft.net/utils/usb_devices_view.html
download the USBDeView software and see if the registry has the player in there....select it and delete it and then plug in your PC again to see if it will re-register the device and works...hope this will help.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Quick question!!
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 20, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
