Kevcast Hi. I was reading you fine. But obviously you could not read anything I wrote. Are you looking for the number for the power supply? And where would I get it? I am in Los Angeles. Thanks. Kevin
  • 1 more comment
  • kevcast Jan 15, 2009
    Please give me the name of the repair place and once again, please tell me what kind of fuses I am to get. And where is the PS panel on the TV.
    90046 Los Angeles, CA
    Any luck finding where I might get them in my area?
    Los Angeles, CA 90046
    Thank you for your help.
    ~Kevin.
  • 4,889 Answers
Thats really wierd looks like some kind of bug. Would you like me to guide you to a repair place where you get both the part and the service. I really think you should try the fuses first.
Posted on Jan 15, 2009
  • eagle338
    eagle338 Jan 15, 2009
    Please get me the zip code
  • eagle338
    You are looking for Cermaic fuses. They will look somewhat like this.http://www.dkimages.com/discover/preview...
    They may be in different colors and sizes but not that hard to locate.
    The power supply board is found when you take the back panel of the set off. It would look like this
    http://www.made-in-china.com/image/2f0j0...
Why won't my TV power on?!
Other than the power supply, it could be a cold solder joint on one of the PCBs. Easy to fix, but almost impossible to find.
Jul 26, 2014 | Samsung PN51D550 51 3D HDTV Plasma TV
Display problem
Not an answer, but I've got ALMOST the same problem. Output is fine, but the meter reads 0000 (both displays). Fixing to open 'er up and take a look - see if I can figure out the problem. If I find anything, I will post the answer here.
Dec 13, 2013 | Agilent E3617A 60 Watt Power Supply
4.6 Liter 99 Lincoln TC has rough idle & loss of power. OBC has NO CODES & NO LEAKS anywhere. Long Term Fuel Trim seems to be steady and reading right, but Short Term Fuel Trim is jumping all over the...
Check the gap on your plugs, also check to make sure you don't have bad spark plug wires. At night start your car and look at the spark plugs IF you see any sparks that look like lightning then you have a bad plug, or wire.
Oct 14, 2013 | Cars & Trucks
How do I diagnose bad power supply, if.....
hi the blue and red cycling is a bad mainboard firmware fault thanks
shaun
Mar 19, 2017 | Polaroid 4011-TLXB LCD TV
Hi Help desk, My Samsung SyncMaster 540N LCD monitor is taking hours of time of display the desktop.what might be the case?Is it due to CAPACITORS popping out? Need a damn help from...
hi there,
Yes, it's capacitors issue.
I will explain how to fix it:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated
  • Replace that capacitor. Done
For More details please read my tips here
Please let me know the result
Thanks.
Dec 16, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Was working fine now wont turn on
Hi just read your posting.Could you please supply the model number for me.Have you checked for power at the outlet?Please reply with the additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Sep 25, 2010 | Fisher and Paykel Washing Machines
I checked power supply and power assy for voltage and its fine. I removed the Y-sus board and started checking for continuity, I started with the fuse (good) Then resistors, I found one very small resistor...
The small green resistor could be a pico fuse, check the markings on the board and look for an F and a number next to it. If that fuse is blown, it means something (Mosfet, transistor) got shorted to blow the fuse. To measure capacitors, you will need a capacitance meter but they rarely become shorted, so I would focus on the mosfets and transistors.
Jan 02, 2009 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Downloading...
ok..no worries.
go to www.lacie.com and look for support downloads..then your model number and o/s..
should do le trique, n'est pais?
and you might consider backing your ext drive up with this option, too...
Mar 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
